Reply 580 of 758, by VileR
- l33t
wrote:That's mode 6? I wonder because you get 80-column text (hard to read in composite) unless you use some tweak (e.g. set mode 4 and switch to hi-res by writing to the CGA mode register, so you're in mode 4 as far as the video BIOS knows when drawing text).
It's mode 6, I just BLOADed screen data originally saved in mode 4 (thus the text).
Yeah, it's interesting about the different order - see also how the text is affected: when it's in black and white (which are on two opposite corners of the square), the edge artifacts will correspond to the other two corners (purple/green on the Apple, light blue/orange on the CGA).
