First post, by Zero Volt
Hello,
after installing MASM611 in dosbox, the window shows a black scree with the following :
C:\MASM611\TMP>_
rgchSourcePath does not contain a drive letter
what should I do to start the program that I just installed ? 🙁
Reply 2 of 3, by Zero Volt
OH 😮 , I just figured out that I didn't specified the right directory to install the program !!! problem solved !
Reply 3 of 3, by eL_PuSHeR
[Thread moved to DOSBox Games/Apps. Section]
