Installation help
First post, by Unregistered
I'm not sure if I'm not installing VDMSound correctly or if I have another issue. When I click on the "Run with VDMS" I get a dos box that has text similar to the one in the FAQ section for how it should look except for the last line.
The last line on how it should read is "F:\games\indy4>_"
Instead what I get is "press any key to continue"
When I press a key to continue, the dos window closes.
I have loaded VDMSound 2.0.4, update 2, and VDMSLaunchPad 1.0.1.1 in that order acording to the readme instructions.
I am running Win2000 Pro on with an Athalon 1.7 (?) I not to sure about all the hardware I have, but I know the sound and video are built into the motherboard.
Also I was reading somewhere that there should be two differant Run with VDMS options when you right click on an executable icon. I only have one.
Can anyone help me?
Thanks
Tim
Reply 1 of 1, by Snover
Update 2 depreciated the first "Run with VDMS" option. It sound like your game is crashing before it starts, which has nothing to do with VDMSound being installed incorrectly. More than likely you've misconfigured the game.
Yes, it’s my fault.
