Technically impressive FM synth music
Reply 120 of 240, by mills26
FM-OPL-Midi-Freak wrote:
...are you able to write music in Adlib tracker 2?
Yes, I can write music in adlib tracker, but i don't use adlib tracker 2, i use reality adlib tracker "rad" 😀
I found more games using loudness sound system.
+ Demonworld (1997), Ikarion Software GmbH
+ Hattrick! (1995), Ikarion Software GmbH
+ Cold Dreams (1995), Immortality Production
Cold dreams even uses pcm drums in the menu song, but I can't find the files inside the game.
There is also some other German game, something about managing a theater, which also uses the lds system.
In case you didn't read mi older post, I contacted alexander brandon, who created tyrian music. He told me only Andras Molnar knew how the lds really works, But I think it will be difficult to find him.
Reply 121 of 240, by FM-OPL-Midi-Freak
Hi Mills again !
interesting, i see the LDS Files from the Game Cold Dreams are *.fsp Files and MCS Files, the header is equivalent to LDS Files
A LDS beginns in Hex: 02 00 43, but i don't know how it ends. In Asci most with a "€" Sign Hex End of LDS Files with 80
It may be true that LDS Files exist in a other Version, it would be interesting how we this LDS Files can play in Winamp
I start Coldreams even and the FM sounds great, the use of PCM its not so mine but a nice intention to this time, i love FM Drums more, however its nice 😉
Now we must try via Hexeditor to experiment until the Song play via Adplug
Greets
Matthias
Equipment:
- ESS Solo (PCI)
- Ess Audio Drive-Compaq (ISA)
- Soundblaster 2.0
-Audioblaster Pro 4.0 at the time puplished by CPS Hamburg
-Sw1000XG / Motif XF
Reply 122 of 240, by mills26
I didn't find any lds header inside the menu from pcgames. I love the songs you posted. are they inside the same menu? I only listened the happy birthday song.
I also tried to play the lds files from cold dreams, if you cange some characters from the header, it will send some data to the opl, but the sound is just some noises, and then, adplug freezes.
EDIT: I did it! just open any file in cold dreams, (I found a scr and a the rest are mcs with the header) then change the first data (03 xx 43) to "02 00 43" The song just plays the opl data, not the pcm, but it already has fm drums, the pcm ones must be stored in another file.
The "converted" lds from cold dream: https://dl.dropbox.com/u/757056/adlib/Coldreams.zip
The main menu music, without the pcm drums (recorded in adplug emulator):
https://dl.dropbox.com/u/757056/adlib/ColdMain.mp3
This web http://www.chiptune.de/ contains nearly all the adlib tunes, I don't know if they will accept these new lds's from cold dreams.
Reply 123 of 240, by RichB93
Shocked that no one has mentioned Streets of Rage 2 on the Mega Drive. Yeah it's OPN2/YM2612 but my god it is something else. Hearing your Mega Drive pump out these tunes is really something to behold.
http://www.youtube.com/watch?v=LJfSz06Qtco
http://www.youtube.com/watch?v=XFcdQObbT8o
http://www.youtube.com/watch?v=6cta2rMTcE8
Apologies for the less than stellar quality but sadly there isn't much online. There might be some MP3s floating around.
Reply 124 of 240, by mills26
RichB93 wrote:
Shocked that no one has mentioned Streets of Rage 2 on the Mega Drive. Yeah it's OPN2/YM2612 but my god it is something else. He […]
They are awesome!, but of course, they are not just FM, there are a lot of PCM samples in them.
Reply 125 of 240, by RichB93
Nope! That's the amazing thing. The Mega Drive only has a single PCM channel that Streets of Rage only uses for SFX. What you're hearing there is mostly the YM2612 with a hint of SN76489. Yuzo Koshiro built the music engine for the game as well as composing the soundtrack and he really managed to get some astounding sounds out of the machine.
Reply 127 of 240, by RichB93
mills26 wrote:
I mean the drums are pcm, the rest is awesome, the chip is far better than the opl2 and other chips in making different sounds.
Have to admit I didn't hear them at first. Whoops 😜
Reply 128 of 240, by FM-OPL-Midi-Freak
First, Mega Drive's ym2612 is awesome, I am almost inclined to think to buy a Mega Drive, than i need transfer Stuff to move all the vgm Files to the Mega Drive ... 😉
@Mills: wow, awesome, very interesting, i haven't seen the different between both Files, its the "02" i tried yesterday a while longer, i idiot, but so its orginal 100% FM Synth 😉
Now i will this Soundtrack take to my LDS Directory 😀
Now we can nearly rip a LDS File from a big resource File, but the end of the LDS File we don't know.
Today i get my ordered ESS AudioDrive ISA, which i can use to play Adplug supported FM Songs via / per true OPL2 in Win98, this function it makes possible, which i can the Adplug-playing record with Cool Edit or Audacity at the same time by internal routing of the Audio Drive, no audio cable its required 😀
As first test record i take the 2-part Song: Ad It Up1, Ad It Up2 (Reality Adlib Tracker *.rad) from the hero: Lois Gorenfeld which is a genius in the matter of write *.rad Files in Reality Adlib Tracker, its all so funky and awesome ! You know this guy ?
If unknown, than get his OPL2 / Reality Adlib Tracker Songs here:
http://www.gorenfeld.net/lou/adlib.php
Of course the other great Demo Guys i know, phandral, nula, hydra, void, encore, Dalezy and so on and this stuff i will record also
last but not least a Image from my FM Directory 😉
And the found PC Games Issues by now, this Package is unfinished, the collecting goes forwards 😉
Read ya later
Greetz
Matthias 😀
Equipment:
- ESS Solo (PCI)
- Soundblaster 2.0
Reply 129 of 240, by sdsnatcher
You posted some really nice FM musics here, and dgilaaa collections of OPL music was particularly impressive.
It's interesting that kool kitty89 posted some info about the YM2413, but no songs from this chip were ever posted here. Since I'm from the MSX community, maybe it's my time to contribute for the nice set of songs available on this thread by guiding you through a tour on the MSX universe.
For those who don't know, the YM2413 (aka OPLL) was the only OPL chip to have a built-in instrument bank designed by the Yamaha engineers themselves. This resulted in very high quality instruments even for a 2op FM synth, and combined with the dedication of the MSX community, this resulted in on of the best uses for the OPL series. Some of them combines the YM2413 with the PSG AY-3-8910, to achive even better results. I hope you like it.
Dragon Slayer 6
Fire Hawk - Thexder 2
Illusion City
Starship Rendezvous
Fray - In Magical Adventure (pt1)
Fray - In Magical Adventure (pt2)
Fray - In Magical Adventure (Dark Mayor - The Final Boss)
Xak - The Tower of Gazzel
Undeadline
Final Fantasy - MSX2 version
Feedback
The Fantasm Soldier - Valis 2
Hydefos
Psycho World
Columns
Tetris
Aleste 2
Space Walk, by Naruto
Battle Stalion - music 3, by Naruto
Battle Stalion - music 6, by Naruto
Bokozuka Wars, arranged by Naruto
Cream Soda - Music 1, by Naruto
Cream Soda - Music 3, by Naruto
Reply 130 of 240, by jwt27
What I like most about the OPL series is that they are basically a full-fledged FM synthesizer in a really tiny chip package. You can make a wide variety of sounds with just a small set of parameters. Having only preset sounds effectively turns the chip into a sample bank, and I think samples are pretty boring.
That said, I just listened to a few of these tracks and yes, they do sound really good! Much better than most DOS games using the OPL2/3, and I think that is because no one ever tried hard to get some cool sounds out of it, except for a few like Tyrian, Xargon and that cheesy minigolf game. There were usually other options available, like GM and MT32, that sounded better with less effort. Being limited to a few high quality presets does make it easier to create good sounding music apparently.
Now for something completely different, though not entirely off topic: I made an OPL3 version of a Jazz Jackrabbit tune last week, and I was wondering what you guys think of it. I personally think I've overdone it a bit, but decide for yourself:
https://soundcloud.com/oplawaai3/tubelectric-opl3
Reply 131 of 240, by 5u3
It's AWESOME! Any chance of you releasing the a2m file? 😀
Reply 132 of 240, by Cloudschatze
Preference notwithstanding, you might (re)visit some of the other recommendations in this same thread. Despite the attention, FM compositions using the Loudness Sound System format (Tyrian, Fuzzy's World of Miniature Space Golf) are hardly the most impressive. But that's my opinion...
Reply 133 of 240, by bristlehog
Agreed. Of what I listened to, X-COM: UFO Defense seems to be squeezing the hell out of OPL3. Highway Hunter has beautiful OPL3 music too, but less technically perfect than X-COM.
Reply 134 of 240, by jwt27
True, I have not heard everything posted in this thread so far. But I do think the semi-reverb effect and overall rich sound of LDS is quite impressive, especially since it uses only OPL2 features (and at the same time, that's also what I dislike most about LDS... it could have been so much better on OPL3).
Reply 135 of 240, by sdsnatcher
@jwt27
But the YM2413 isn't restricted to the built-in presets. You can also load a custom instrument if you want. The vast majority of those musics make extensive use of custom presets.
Of course the OPL2 is much more flexible on that can be done. Anything that can be done on the OPLL can be directly translated to the OPL2, since both feature the same synthesis core. The idea of that post is exactly to show how far the OPL2 can easily go.
BTW, that's a really nice remix of the Tubelectric song! Congrats!
Reply 136 of 240, by jwt27
Whoa, thanks! 😀
Here's the A2M file attached below.
    TUBELECT.zip
    3.39 KiB
    199 downloads
    Tubelectric adtrack2 module
Reply 137 of 240, by jwt27
sdsnatcher wrote:
@jwt27
I understand, but still having only one user definable instrument is a pretty big limitation.
Not saying that's a bad thing though. it's cool to see a more restrictive chip being put to better use than the original. More limitations lead to more creativity 😀
Reply 138 of 240, by FM-OPL-Midi-Freak
@sdsnatcher
seemingly you are a fan of msx fm music
recommendable its some scene music of the msx If not already known, the moonblaster mbm file format is interesting
to play the some different fm orginal formats, you need 7 drivers:
MBR143.001
MGSDRV.COM
MBR143.001
MPK.BIN
MPK103.BIN
OPX4KSS.BIN
FMPAC.ROM
This drivers must added in XMPLay or winamp
MSX-FM-Drivers.zip
39.03 KiB
162 downloads
and here the winamp plugin
direct link
http://dsa.sakura.ne.jp/arc/bin/wa2msx/wa2msx061213.zip
source page
http://www.pokipoki.org/dsa/index.php?MSXplug
for nice browsing in this stuff / music you can visit this follow paradise, i wish i had the original hardware to play this beautiful songs, but the emulation its ok also
http://www.mmnt.net/db/0/0/ftp.nekochan.net/p … /pub/msx/music/
Here i have a little collection of good examples, it could be, that some songs overlaps with hoot users, but doesn't matter
Best.rar
71.6 KiB
140 downloads
little MBM samples / game tracks
by the way, the difference between kss playing in XMplay and the mbm version its neat
i forgot Aleste, here both versions to compare
Aleste.zip
11.25 KiB
117 downloads
kss / mbm file
one of the very nice examples its "bucket.mbm" with a beatiful synth lead which had a special long LFO setting
apropos hoot, pity that doesn't hoot used no real hardware, of all kinds of ym(xxx) chips
Matze
Equipment:
- ESS Solo (PCI)
- Soundblaster 2.0
Reply 139 of 240, by Malik
Speaking of Sega Megadrive, have anyone heard SubTerranea Level 1 Music?.
Gets better and better on the way. I prefer to hear it with deep (or deeper) bass.
