Sony Trinitron CRT
First post, by silikone
Sony's high-end Trinitrons seem to be the best CRT monitors out there according to many sources. The FW900 in particular is popular among enthusiasts, but is it the ideal retro CRT? Since it's 16:10, you'd have to pillarbox to avoid stretching. A native 4:3 monitor would perhaps be more suitable. Obviously not ideal for widescreen content, but that tends to be 16:9 anyway. I've been looking at the F520, which appears to pretty much be a FW900 with a 4:3 aspect ratio. Do you think this is the one to go for?
Do not refrain from refusing to stop hindering yourself from the opposite of watching nothing other than that which is by no means porn.
Reply 1 of 12, by RacoonRider
I currently use IBM P76 17" monitor for retro gaming. It's a trinitron, Sony E220 tube. I haven't seen anything better.
Reply 2 of 12, by Great Hierophant
The F520 is a good choice if you like Aperture Grill style CRTs. I prefer a shadow mask CRT myself. More prevalent technology during DOS gaming years.
Reply 3 of 12, by Hatta
IMO, the best CRT monitor is the NEC FP2141SB/Mitsubishi 2070SB. It's the same monitor in a different housing. Incredibly high resolution, incredibly sharp and vibrant. Also incredibly big and heavy. But that comes with the territory.
Reply 4 of 12, by Anonymous Coward
I liked the the Sony FS II that I used to have. It was beige with digital controls. Looked good on on my retro systems with a nice sharp picture.
http://www.computerdisplays.co.uk/15%20inch%2 … ny%2015FSII.htm
Reply 5 of 12, by CwF
I had dual SGI somethings for ten years or so that were 16:10 and 24" or so, mammoths, and they were beautiful. I could have them as dual, and single or duals on secondary computers since they were multiple inputs. I think maybe 3 with vga, bnc, and 13w3. That now runs dual 40" samsungs and is simply hard to argue with, so those beast went away. I don't think the aspect is an issue. It is only a benefit, you can always square up any aspect and ignore the blank space and pretend it is a 22". Those old ones had easier analog adjustments, squared up or stretched, your choice.
Those boxes were the size of a washing machine.
I used to know what I was doing...
Reply 6 of 12, by Unknown_K
I love Sony Trinitrons. Still using a 17" SF II a 15" SF and have a 19" 420GS in the garage that needs repairs. There were also quite a few other models that used SONY tubes made by different manufacturers and Diamondtron tubes made by Mitsubishi after the patents expired.
You can run all kinds of resolutions and still have a nice display (even old cutom mac ones if you like Mac gaming).
17" or the late 19" are the best for desk space, weight, and resolution. Very early Trinitorns can weight 100lbs or more and give off a ton of heat (the old fixed frequency ones).
Reply 7 of 12, by d1stortion
Tritrons seem to deteriorate more than other CRTs. Have two with the exact same problem: white colors smearing on black...
Reply 8 of 12, by SquallStrife
I have a handful of Trinitrons...
A PVM-2950QM and PVM-1442QM, 29" and 14" respectively. Both are 15kHz RGBs monitors, the 14" also supports TTL CGA.
A 29" KV-SW29M31, a plain Trinitron TV currently being used as an arcade monitor.
Two 21" Dell P1130 monitors. Currently using one on my retro PC setup, and the other is in storage.
Reply 9 of 12, by Stojke
Where did you get an PVM 2950QM?
Reply 10 of 12, by SquallStrife
Government disposals auctions, cost me a whopping $3. 😀
Reply 11 of 12, by Stojke
Holy s*** , now thats a deal. I'm jelly 😀
Reply 12 of 12, by jwt27
Analog controls are easy, but most monitors with digital controls will store the dimension settings for each resolution, which is even easier.
