First post, by lucky7456969
mount c c
boot "CD\" -t iso
tried
imgmount j "D:\games\blah\abc.img" -t iso to no avail
I want to mount and start the image from, take an example, Drive J?
Thanks
Jack
Reply 1 of 17, by leileilol
I'm pretty sure floppy disks never used the ISO9660 file system
Reply 2 of 17, by lucky7456969
So I can't make it more convenient to load except for using frontends?
Thanks
Jack
Reply 4 of 17, by lucky7456969
I want to start the floppy image as if it is in a local drive
Like when abc.img must be started by boot "CD\" -t iso
Now I'd like to mount it onto J drive, so that it is mounted automatically everytime I run dosbox.
Reply 5 of 17, by SquallStrife
Lay off the weed bro.
Reply 7 of 17, by Jorpho
lucky7456969 wrote:
Like when abc.img must be started by boot "CD" -t iso
Nothing has ever been started this way.
Reply 8 of 17, by SKARDAVNELNATE
How to mount a floppy image
IMGMOUNT A "C:\<path>\<disk.img>" -t floppy
when It was started like this before?
Can you elaborate on what you did before, exact step by step, and what happens when you try it again?
Err... Not clear on why you want it as J but to mount every time you can add the mounting command to the [autoexec] section of the conf file.
Reply 9 of 17, by lucky7456969
imgmount a E:\games\flight\fsim1.img -t floppy
I am afraid there is no working.
fsim1.img is surely working by simply booting. But it doesn't mount to drive a of dosbox.
Thanks
Reply 11 of 17, by lucky7456969
I put the line into the autoexec section of dosbox.conf.
But when dosbox is started, I type 'mount', drive a is not listed.
Reply 13 of 17, by lucky7456969
Can't create drive from file.
Thanks
Reply 15 of 17, by lucky7456969
I believe so. Read-only, Can I unzip it and rezip it back?
Thanks
Jack
Reply 16 of 17, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Actually, as someone else figured out, you might be trying to mount the floppy image of MS FS1 and that is a booter game. Many of those don't have a valid file system to mount...
SERIOUSLY: Please provide as much INFORMATIONS as possible. Why should we take part in your guessing games? I refuse to answer yur posts from now on...
unzip/rezip it? seriously? It's an image NOT an archive...
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 17 of 17, by exofreeze
Looking at the original post it is obviously a booter game.
type this
boot E:\games\flight\fsim1.img -l a:
