First post, by northernosprey02
I have one question for early preparation
Is PIII Tualatin works with i820 mobo via PowerLeap slotkets?
Reply 1 of 5, by Logistics
First few results in Google, sir. Apparently, it can work, but is problematic and only select cases being truly successful.
Reply 2 of 5, by sliderider
I don't know that you would really want to do that. i820 requires RDRAM and RDRAM is not known to work well with Pentium III. RDRAM works a lot better with Pentium 4.
Reply 3 of 5, by flupke11
Afaik it should work. i820 boards with rimms are not that bad and were made with 133Mhz cpu's in mind. It's difficult finding a good slot 1 mobo that does 133 native.
The boards you should avoid are the i820+MTH+Sdram combination, they are not stable.
Reply 4 of 5, by northernosprey02
Fortunately, my HP Vectra VL600 doesn't has MTH 😀
But what's wrong with VIA 133 Slot 1 mobo?
Reply 5 of 5, by flupke11
Nothing's too wrong with Via chipsets for that era, but Intel chips tend to perform better on all levels.
