First post, by keropi
- l33t++
Hiya!
While I am waiting for 2 midi modules to arrive I want to be ready and have all needed cables for when they finally come 😊
The plan is to connect a CM-32L , a SC-55 mk1 and a MU-80 to my p1 build via an MPU-401AT card.
For now I have the CM-32L connected and working great 😁 but what about the rest? I have 2 questions on the matter:
a. Will a connection like in the following diagram work? (using the module's THROUGH sockets)
Module A gets connected to pc and it's through port goes to module B's IN.
The B's THROUGH port gets connected to C's IN. I am almost certain that it will work, but it doesn't hurt to ask 😊
b. Do the modules need to be powered for their THROUGH port to work?
If for example I have module A powered OFF and module B powered ON , will the pc signal reach module B ?
thanks in advance for any info/help! 😎
🎵 🎧 ⏳ ⚡ SoundVision PRO,MK1869 , PCMIDI MPU , OrpheusII , Megacard and 🎶GoldLib soundcard website
