First post, by mseals
I am working with old pos software for my brothers computer. .Just FYI it hasn't been supported since late 80's and I have permission from the author to do to it what ever I want ... anyway I had it working on an old windows 98 machine and the hard drive crashed so I am working on a backup I had to put on a old windows 95 machine .. problem is I edited some files not in the program to make it work and now I don't remember what they were.. when I try using your software it wont work on the main because it needs to create a partition on the hd when it runs .. but the client will run .. unfortunately the client without the main isn't any good 🙁 any ideas or help would be greatly appreciated
Mike Seals
Reply 1 of 13, by SKARDAVNELNATE
Maybe Virtual PC.
Reply 2 of 13, by mseals
I already have the windows 95 pc I just need to know if I need a modified dll or something that lets dos box run without the program
Mike Seals
Reply 3 of 13, by Jorpho
Are you sure that's exactly what it is trying to do? Because that's a pretty strange thing for a DOS program.
If it comes to that, it's probably going to require direct disk access. You might get a little further booting a hard drive image in DOSBox. See for instance Install DOS in DOSBox .
mseals wrote:
SKARDAVNELNATE wrote:
Maybe Virtual PC.
No, he means Virtual PC. It is much more complete than DOSBox. VMware and VirtualBox are other alternatives.
Reply 4 of 13, by SKARDAVNELNATE
I'm fairly sure DOSBox can run without Windows 95 already.
Reply 5 of 13, by mseals
yes dosbox will run without windows 95 .. I don't need the dosbox program I need to figure out a way to run an older dos program on a windows 95 machine preferably without dosbox.
And the point of the matter is it was running on a windows 95 machine I don't need a new environment I need to know what I need to change in windows 95 to make an older dos program to run in it.
Mike Seals
Reply 6 of 13, by collector
Try editing a PIF for it to set what ever the program needs. If it refuses to run properly in Windows, set the PIF to start in pure DOS.
Reply 7 of 13, by Jorpho
You seem very confused.
Generally, DOS programs either work in Windows 95 or they don't.
I ask again: is the program actually giving you a message about "creating a partition on the hd when it runs" ? Are those the exact words it is using? Because that has nothing in particular to do with Windows 95.
Reply 8 of 13, by mseals
if I use dosbox yes without it no it runs but the window has a bunch of dos commands in it instead of the clean environment it should have without showing the commands
Mike Seals
Reply 10 of 13, by Joey_sw
thats 80s software right? so it must be DOS progam
IF you're mean to use that program WITHOUT mulit-tasking/switching to another windows program:
Edit the MSDOS.SYS
to make it boot to command line.
http://www.mdgx.com/msdos.htm
-fffuuu
Reply 11 of 13, by Jorpho
Joey_sw wrote:
thats 80s software right? so it must be DOS progam [
Edit the MSDOS.SYS
That is the same thing as selecting "Restart in MS-DOS Mode" from the shutdown menu (or setting the appropriate option in the PIF file).
Reply 13 of 13, by eL_PuSHeR
[Thread moved to DOS Section]
