First post, by MiniMax
- Moderator
With DOSBox 0.61 the game is somewhat runable. It needs ems=false in the [dos] section, or it will complain with "EMS driver is not VCPI complaint." when starting the installer.
Also, exiting from the installer, or from the game, results in a fatal DOSBox error, "Exit to error: Page fault didn't correct table.". but all the game settings seems to be saved on disk.
Things that makes the game un-playable
- Problem with stuttering sound, both during video sequences, and dialogs (particular annoying!). I tried upping the frameskip, upping the sound blocksize, lowering the sound rate, different CPU cores - but to no avail.
- Problem with keyboard double'ing up on key presses. Occurs both in the DOS-based installer, where a menu entry can get "jumped", and in the main game (makes it hard to exit the game using Alt-X followed by "Y" for yes, since the Alt-X is doubled up).
MiniMax
_________________
