First post, by Soupdragon
Does anyone have a updated BIOS for this board that supports CPU speeds over 800MHz. Abit no longer has a web site.
Thanks
Reply 1 of 10, by Jolaes76
The max multiplier is what you can see in the BIOS. If it is 8x you are not going to get further. The latest bios (QS) might solve other issues.
http://pross.org.uk/Abit/bios/bx6/
"Ita in vita ut in lusu alae pessima iactura arte corrigenda est."
Reply 2 of 10, by Soupdragon
thanks 😀
Reply 3 of 10, by Jolaes76
One more thing:
official multiplier support in BIOS does not ALWAYS mean that a higher multi CPU will not work. But you cannot take it for granted.
Read this as well:
http://forums.anandtech.com/showthread.php?t=651167
(I have a BH6 with an Abit Slotket III + a 10x100 Coppermine P3 CPU. This works without problems.)
Reply 4 of 10, by Soupdragon
I have what I think is the latest bios file now bx6qs.exe but I need the flashing software for dos so I can use the bin file. Does anyone know where I can find the correct version of AWDFLASH.EXE does the version matter?
Steam | World of Warcraft
Reply 5 of 10, by Jolaes76
http://www.wimsbios.com/awardflasher.jsp
You should try v 7.52 or above.
Reply 7 of 10, by Soupdragon
When I try to write the new bios the flash program states:
The Program file's part number does not match with your system!
So I didn't continue trying to flash it. I am trying to update the bios so that it properly detects my Powerleap adaptor with Celeron 1.4Ghz CPU. At the moment it says 1368Mhz as the pc boots up.
Reply 8 of 10, by elianda
In my mirror archive there is also a bx6r2 folder, maybe this bios is more fitting?
ftp://78.46.141.148/mirrors/ftp.abit.com/pub/download/bios/
from this mirror it might be the same content
ftp://78.46.141.148/mirrors/www.elhvb.com_mob … kive/Abit/bios/
Youtube Channel
Reply 10 of 10, by Soupdragon
It successfully updated with bxrqr.bin which should be the latest. Big thanks to Jolaes76 and elianda. 😎
