PCEm. Another PC emulator.
Reply 140 of 1046, by justincase
Sorry for asking for Pentium P5 emulation, but sometimes the virtual mouse stops working.
Reply 141 of 1046, by Alegend45
Don't apologize, just use a different emulator in the meantime. Bochs sounds more suited to you than PCem.
Reply 142 of 1046, by justincase
For example, when I exit MS-DOS on Windows 3.1x the virtual mouse stops working.
Reply 143 of 1046, by Alegend45
I think the initial report was fine. Also, did you read what I posted?
Reply 144 of 1046, by justincase
@Alegend45
Yes, but I'm just sticking to 486 and earlier emulations.
Reply 145 of 1046, by leileilol
It'll happen in Windows 95 too.
FUCK "AI"
Reply 146 of 1046, by Alegend45
justincase wrote:
@Alegend45
I mean the part about using Bochs instead of PCem. Seriously, you sound more like Bochs is for you.
Reply 147 of 1046, by justincase
Therefore, I must be patient and wait before going back to PCem.
Reply 148 of 1046, by leileilol
I'd recommend QEMU over Bochs, personally. Bochs seems more like a reference emulator to learn and pick apart from with a focus on being in C for as many platforms as possible rather than something usable for general purpose, which makes me believe the people that recommend Bochs never used it themselves.
FUCK "AI"
Reply 149 of 1046, by Alegend45
I have, and I've even looked at the source code, which BTW, is a huge mess. QEMU may be faster, but I tried using it, and I couldn't get it working.
Reply 150 of 1046, by justincase
I discovered a bug that prevents changes to the virtual BIOS system date, which is required to run betas of Windows 95.
Reply 151 of 1046, by Jorpho
Instead of just saying "I discovered a bug", it would probably be more helpful if you describe exactly how this bug can be reliably re-created.
Reply 152 of 1046, by justincase
To re-create the bug we would:
1. Emulate an AMI 486 WinBIOS.
2. Run SETUP.
3. Click Standard > Date/Time and - or +.
Reply 153 of 1046, by Jorpho
justincase wrote:
2. Run SETUP.
Come now, all you said is "betas of Windows 95". Which betas of Windows 95?
Reply 154 of 1046, by leileilol
AMI486 WinBIOS doesn't have the date working IIRC. It'd keep going to 1980. I think it's a known issue already
FUCK "AI"
Reply 155 of 1046, by justincase
It happens on a real machine too?
Reply 156 of 1046, by leileilol
Yeah, if you take out the battery or have a defective one 😀 Try using the AMI 486 Clone bios instead, which should show up with some better Y2K compliance.
FUCK "AI"
Reply 157 of 1046, by justincase
But if the battery is present and working, there's no problem.
Reply 158 of 1046, by Stiletto
SarahWalker wrote:
This isn't going to change unless someone comes up with a UM8881F datasheet, and to be honest it's not something I'm that concerned about - the AMI BIOS on my site largely works, and there are other boards that can be emulated.
I have a knack for finding stuff like that. Is there anything else you are looking for?
Likewise, if there are any datasheets you struggled to find but eventually found while working on PCem, would you mind sharing them?
I'm starting to lay the prepwork for MESS's PC-emulation datasheet collection, I wouldn't mind killing two birds with one stone...
do the Fandango!" - Queen
Stiletto
Reply 159 of 1046, by justincase
I tried to compile PCem with SiS 496 emulation, but it's missing the SiS496.h file!
