a question
First post, by COG_DragonLord
ok once ihave a cd mounted how do i install a game of of it? can i even do that?
Reply 1 of 8, by COG_DragonLord
sry for tyhe double post 🙁
Reply 2 of 8, by eL_PuSHeR
Get a ms-dos crash-course fella.
Change to the cd drive -> X:
X:\>
and type in DIR /p for a directory listing. Search for .BAT .COM and .EXE files like install.exe setup.exe , etc...
Reply 3 of 8, by COG_DragonLord
interesting well i'll have to se if it works.
Reply 4 of 8, by COG_DragonLord
ok i did and this is what my thing looks like D:\> so im in the cd but when i type install (thats the name of the application) it says illegal command.
Reply 5 of 8, by eL_PuSHeR
It must be called differently. do a dir /p command
Reply 6 of 8, by COG_DragonLord
k i did but it still dosn't work so i dunno if u wanna look at what it says go to my webpage http://members.cox.net/dgz_dragonlord/ and i have psoted a screenshot of my command console.
Reply 7 of 8, by COG_DragonLord
some respond
Reply 8 of 8, by eL_PuSHeR
I see an AUTORUN.EXE, INSTALL.EXE and SETUP.EXE - For the love of GOD, type in Autorun and press enter.... If autorun fails, try executing install.exe first.
EDIT pt2: if this is a WINDOWS game, why in the hell are you using DOSBox? If it's a ms-dos title, you are fine then.
