First post, by Great Hierophant
- l33t
In the PCjr. mode, this is what is displayed in 0.74 :
This is identical to the graphics displayed in the CGA mode.
In the latest SVN, this is displayed :
This gives a four color combination not found on the CGA. I wonder if the white color should be light gray.
I know that much has changed since 0.74, including removal of the CGA Color Select and Mode Control registers in the PCjr. machine type, but as the Jr. was supposed to be BIOS compatible with the PC, I would have thought that the CGA colors should be identical (except for intensity).
