Can't Install DOS Game
First post, by I Am Tosk
Hello, this is my first post on your forums. I am trying to install Star Trek 25th Anniversary Edition (CD Version) to my computer. I am running the most recent version of DOSBOX.
To launch the installer I type these commands.
  • mount e e:/
    e:
    install
Once the game launches, I try to install the game to c:/TREKCD (the default installation spot).
When I hit install game I get this message "The Drive You Named is Unavailable". Also when I get this screen this line appears in the status window "redirect output to NUL" I have tried installing things to other places with no luck. Any thoughts?
Reply 2 of 7, by SKARDAVNELNATE
I Am Tosk wrote:
To launch the installer I type these commands. […]
  • mount e e:/
    e:
    install
You mounted the drive as E
You told the game to install to C
Use mount c e:/
Reply 4 of 7, by I Am Tosk
SKARDAVNELNATE wrote:
You mounted the drive as E […]
  • mount e e:/
    e:
    install
Use mount c e:/
When I did this I got a message that said "file not found"
These are the commands I used:
mount c e:/
c:
install
Reply 6 of 7, by I Am Tosk
I got the game working! Thanks everybody! One more thing really really simple question. How do I set the cycle speed to 10,000 in the config file?
Reply 7 of 7, by SKARDAVNELNATE
I Am Tosk wrote:
When I did this I got a message that said "file not found" These are the commands I used: mount c e:/ c: install […]
mount c e:/
c:
install
You need to mount both a source drive and a destination drive.
[cpu]
cycles=10000
