First post, by manfred
Hallo,
i use dos very often for i.e. for games, programming basic, -
and i do not understand how to generate a language file for german keyboard as discribed in readme.txt
Could you explain me step by step, please.
Where can i download such a german language file??
Reply 1 of 7, by Markus
The language file has nothing to do with your keyboard, using one will only replace the strings that dosbox prints on the screen, i.e. dosbox will talk german instead of english.
Start dosbox,
type "config -writeconf german.lang",
quit dosbox,
start notepad german.lang and find your dictionary and translate everything in the file.
To use your language file start dosbox like this: "dosbox-lang german.lang"
Reply 2 of 7, by Qbix
Rank DOSBox Author
DOSBox Author
config -writelang german.lang
that would be
Water flows down the stream
Reply 3 of 7, by manfred
i dont understand. every attempt without sucess. could you give me examles or a german.lang to order dosxbox with -lang german.lang.
Reply 4 of 7, by manfred himself
OH i see. Thank you for help -> an output of the german translation, isnt it?
But how i can replace asci with german charcter, i.e. öäüß ??
Reply 5 of 7, by MiniMax
Rank Moderator
Moderator
What is stopping you?
_________________
Reply 6 of 7, by manfred himself
I mean usage of german keyboard and keyboard output üöäß[/b]
Reply 7 of 7, by MiniMax
Rank Moderator
Moderator
You did try to search, didn't you?
german layout
German DOSBox Forum
cant put "\" at dosbox
How do i get ~ symbol in dosbox?
Alt Gr does not work
problem with the keyboard
keymap support?
_________________
