First post, by leonardo
Hello everyone.
I'm new here, though I'm not new to old games or retro hardware in general. After practically every google search kept leading me here I decided it was time to join. Clearly this community has something to offer those who love old systems and games.
Anyway, my problem has to do with DOS games on a system with two sound cards. The cards in question are Turtle Beach Montego A3DXStream (Aureal Vortex) PCI and AOpen FX-16 ISA (ESS AudioDrive ES1868F). The former I keep because it's a really good card for Windows and features 3D sound for a multitude A3D games. The latter I want to use for games that require SoundBlaster compatibility (ie. DOS games).
With only the Turtle Beach card in my system I had a problem with some DOS games simply refusing to work (black screen during start-up or a lock up during sound card configuration) and I just assumed it had to do with emulation not being perfect. The games that did work couldn't use the MIDI daughter card on my Vortex and the emulated FM sounded quite crappy so after a lot of research I decided to get a separate card that was the real deal and disable the SB emulation. Unfortunately, things are now worse than before!
The games that gave me trouble before still don't work, but now even some games that used to run have stopped working. For example the LucasArts adventures all used to run on the crappy emulated FM, but now hang mid-note thru the LucasArts logo! I'm starting to think there is some other problem with my configuration that is interfering with SoundBlaster compatibility (emulated, or otherwise). I've played around with IRQs and other resources (ideal setting for a SoundBlaster ought to be IRQ7, DMA1 and base address of 220, according to http://www.oldskool.org/guides/oldonnew/sound). I've tried setting things with esscfg.exe, by reserving resources in the BIOS and overriding automatic configuration in Windows and I'm starting to get grey hairs over this. 😵
The full hardware list is here: My oldest rig, Hyundai HD-P5233M
I'd appreciate any input you have. I'll do anything from full OS reinstall to rearranging cards to changing BIOS settings. Thanks in advance!
[Install Win95 like you were born in 1985!] on systems like this or this.
Reply 1 of 11, by duralisis
I've had similar issues tryting to get a TBSC working simultaneously with a Yahama YMF724 card. The SB emulation can sometimes be hard coded to work only with a certain DMA channel or PCI IRQ, and the other card can interfere. Try running only the ESS and pull the Montego. Also look for resource sharing conflicts like a "printer" IRQ sharing setting or reserved ISA DMA.
Reply 2 of 11, by gerwin
So you got an ESS AudioDrive ES1868F based card and Sound Blaster support is still bad!? That card should work for almost any game out there. The 430TX chipset motherboard should also support DOS in every way.
Try to use these resources: SET BLASTER=A220 I7 D1 T4. Make sure the LPT port is not on IRQ7, set it to 5 in the BIOS. Do not reserve resources in the BIOS for legacy ISA, as the ESS card is PnP. Test it in pure DOS (F8 at boot), then run esscfg.exe from the DOS prompt, then try a game.
Some DOS games support ESS Audiodrive directly, does that work?
Reply 3 of 11, by leonardo
Thanks. I am looking at the removal of the Turtle Beach as a means of troubleshooting this issue, but I want to keep both. FreeSpace2, Unreal, Thief and System Shock2 all feature A3D audio support and I'm going to have it all! 😈
The LPT on this rig defaults to IRQ7, so clearly I'm going to have to move that elsewhere...
Exactly. Apparently I'm doing something wrong since I have all the right parts. Looks like my first mistake was made in the BIOS (I did reserve resources for Legacy ISA because I thought it meant the sound card would default to using those!).
Based on advice from you both I tried these things:
  • Moved LPT1 to IRQ5/278H (the only option that is not IRQ7)
  • Disabled reserved resources in the BIOS
This moved the AudioDrive to IRQ7 with DMA channels 0 and 1 (why does the card use channel 0, does anyone know?), but the base address is 240 because my NE2000 ISA ethernet wants 220 and refuses to let it go). I wonder if I should pull that out and put a PCI 3Com in its place...
I'm going to try that next and if that doesn't help I'm going to pull the Montego to see if it that fixes the issue.
Reply 4 of 11, by leonardo
Okay.
I feel like some progress is being made. Here are my observations:
...after removing the Realtek NE2000 compatible ISA ethernet.
  • The AudioDrive in Windows defaults to IRQ10, DMA1 and base 220.
  • SimCity2000 configuration utility detects the settings correctly but trying to run the game results in a black screen.
  • Day of the Tentacle now runs, but all speech is cut after second by silence. Also the cursor fails to appear after the intro (weird).
  • Under DOS, Day of the Tentacle first complains that it wants more RAM, then hangs on a note at the LucasArts logo.
  • Under DOS, SimCity2000 runs(!) but with absent sound effects. Only music is played. The setup utility actually fails to detect any SoundBlaster model for effects when run in DOS.
...putting the Realtek NE2000 compatible ISA ethernet back into the machine.
  • The AudioDrive in Windows is now using the ideal settings (IRQ7, DMA1 and base 220).
  • Day of the Tentacle crashes during the LucasArts logo with a hanging note.
  • Under DOS, esscfg says 'Failed configuration register address test'. No games detect any sound at all!
Reply 5 of 11, by leonardo
Enabled Plug&Play OS setting in BIOS (thus allowing Windows to set up the hardware). This again changed around the hardware addresses but I was finally able to get the AudioDrive to the preferred settings by manually setting PCI device IRQs in the BIOS (AudioDrive wanted to go to IRQ10, but not given that option it finally settled down to 7). 😀
I'm now back to the situation where most games seem happy.
I quickly tested a bunch of old DOS games and they all ran without hiccups except for DOTT:
  • Commander Keen in Goodbye Galaxy
  • WORMS United & Reinforcements
  • King's Quest 7
  • Dyna Blaster (Bomberman clone)
  • SimCity 2000 (yes, even in Windows!)
  • Command & Conquer
  • Monkey Island 2 (this one seems to use the Turtle Beach synth though, eww).
  • Molez
The only games left that give any trouble are the older Scumm based adventures like DOTT and Sam n' Max. Those crash to the desktop with the hanging note during the LucasArts logo and a message about Illegal operation or Invalid instruction. Trying to run them from DOS results in the hanging note and freeze, no error message, but right before crashing the game complains about how it wants 15k more memory and that the amount of EMS available is less than 2 MB. I suppose I can just use ScummVM in Windows and set that to use the ESS AudioDrive or the Terratec Wave XTable on the Turtle Beach...
So looks like I solved the case. I now have a dedicated SB PRO that works with most DOS games.
Reply 6 of 11, by pyrogx
Your computer is probably too fast for running some older DOS games. I have a similar setup here (Asus TX97, K6-III/400) and I am using slowdown utilities (like this one http://bretjohnson.us/programs/slodn310.zip) or disable the CPU cache. DOTT for example only runs if I disable the L1 cache.
Reply 7 of 11, by gerwin
Good!
Setting up PnP resources is really shitty for ISA soundcards. Usually there is a way to get the soundcard on the desired resources, but it takes effort.
For example:
-On the Asus P2B motherboard, setting LPT to IRQ 5 still results in programs detecting IRQ 7 to be occupied by LTP. So I had to disable LPT entirely.
-Crystal CS4232 PnP soundcards want to be on IRQ 5, so you actually have to occupy 5 with something (LPT/Reserve Legacy ISA) to get it to 7. Actually it still did not cooperate enterily: I modified the PnP key data in the soundcard EEPROM so it only accepts A220 I7 D1, and nothing else. These cards are really easy going since. 😀
Reply 8 of 11, by leonardo
This could in fact be the case. It just never occurred to me. Thanks for the hint!
In other news, what I did - turns out - also fixed the emulation on the Turtle Beach card. 😦
That's right. What I did in trying to fix the actual SoundBlaster rendered the whole purchase kind of pointless. 🤣 Oh well...
If I disable the AudioDrive and re-enable the SoundBlaster Pro emulation the emulation takes up the exact same resources and now appears to fully work with all games. Some games (like C&C for example) actually sound better thru emulation. I suspect it has to do with a higher sample rate on the Turtle Beach or something. Games that use synth sound better on the AudioDrive. Hmm... I suppose in the end since using either is just a reboot away, it's not a big deal. Interestingly DOTT works with SB emulation but not with the AudioDrive. Could the emulation slow the system down just enough for it to work?
Also, I discovered after my altered settings that when using the SB PRO emulation on the Turtle Beach card I can use the Terratec Wave XTable in DOS. In Windows it doesn't work, but in pure DOS mode it works. Games with General MIDI support sound great, but the volume is way too loud compared to the sound effects.
This has been most educational. Will have to see how rig #2 fares when I have time for it...
Reply 9 of 11, by ik777
leonardo wrote:
Okay.
[*]Under DOS, Day of the Tentacle first complains that it wants more RAM, then hangs on a note at the LucasArts logo.
If this problem is not a base memory problem, I can help you this. Pure DOS with more than 32MB RAM always make troubles.
I heard one solution is "OS/2 Installed - Yes" in bios setting.
My solution is "Use a Ramdrive" for reduce your Ram. I got a 64MB machine, Using 32MB of SRDISK make my machine can run games reporting I have (Minus)-????K XMS or EMS.
Reply 10 of 11, by swaaye
The daughtercard header on that Vortex 1 should work in DOS when the SB emulation driver is loaded. It also emulates MPU401. I've done it myself with that exact Montego A3Dxstream card.
Reply 11 of 11, by leonardo
ik777 wrote:
If this problem is not a base memory problem, I can help you this. Pure DOS with more than 32MB RAM always make troubles. I hea […]
leonardo wrote:
Okay.
Thanks for the hint. SimCity 2000 for example complains that the amount of memory is negative. However it still runs just fine.
I've confirmed it does in DOS. I wonder why it doesn't work in Windows though.
