First post, by GeorgeMan
- Oldbie
Hello there! I recently discovered this forum and fell instantly in love with your retro PCs. I'm only 23 y.o. (yes, born in 1990) but I have spent numerous days reading about old hardware and trying to find some, as my first PC was a s478 Celeron w/ XP.
So I came into a PC with Intel 82430TX motherboard, Pentium MMX 166MHz, 2x16MB 72pin edo ram, S3 Trio 64V+ 1MB PCI VGA, Seagate Medalist 2GB HDD, a single floppy and a CD-ROM.
This is the motherboard:
I upgraded it some years ago with a CD-Rom, 64MB SDRAM, Fujitsu 6.4GB HDD and a Pentium 233MHz MMx. Unfortunately, the mobo died. Whatever I tried to do, it kept beeping and no signal on monitor.
But I was lucky! I found a QDi Advance 2 AT motherboard, which not only was compatible with all the rest hardware, but was fully operational and came with an AMD K6 266MHz CPU and has an AGP slot!!! It even supports ATX PSU and soft off! I even found the manual online and hand made 2 USB plugs from the onboard headers.
Here is my baby:
Recently I bought for €1 a Diamond Monster 3D (3dfx Voodoo 1), so I ended up with a PC made of these:
* AMD K6-266 oced to 300MHz
* 128MB SDRAM (2x64)
* S3 Virge/DX 2MB --> upgrade from S3 Trio64V+ 1MB
* 3dfx Voodoo PCI 3D
* Seagate X Series U 20GB 5400rpm silent --> motherboard limit is 32GB
* Dual floppies
* Samsung CD-ROM
* Soundblaster Live! SB0060 (EMU 10K chip) --> Upgraded the rubbish Opti16 ISA audio card
* Windows 98SE
Now the question!
I have an ATX socket 7 motherboard (Gigabyte GA-5AX) with an AMD K6-III 400MHz CPU.
I also have another 2x64 and 1x32MB SDRAMs, an 80GB HDD (supported by the 5AX) and an Nvidia Riva TNT2 M64 32MB AGP VGA. I also have an ISA Creative Vibra16S with Yamaha chip.
What do you suggest me to do?
Is it a good idea to have the K6-266 along with 96MB RAM and the Vibra16S and the S3 Virge 2MB for DOS gaming and the K6-III with 192MB RAM, the SB Live!, the Riva TNT2 M64 and the Voodoo for Windows games, both with Windows 98SE?
Or is not worth the hassle and I'd better combine the DOS and the Windows vintage gaming in one (the older) machine?
Thanks and please help!! 😊
Acer Helios Neo 16 | i7-13700HX | 64G DDR5 | RTX 4070M | 32" AOC 75Hz 2K IPS + 17" DEC CRT 1024x768 @ 85Hz
Win11 + Virtualization => Emudeck @consoles | pcem @DOS~Win95 | Virtualbox @Win98SE & softGPU | VMware @2K&XP | ΕΧΟDΟS
