Have you opened your SC-55 to check the battery inside?
Reply 20 of 420, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
In my case the glue was used to fix some wires on the bottom side of the PCB. It was the sort of stuff that crumbles when removing it.
1+1=10
Reply 21 of 420, by sliderider
It's probably hot melt glue. It's applied hot then hardens as it cools. That stuff tends to become crumbly over time as it dries out. After this much time, it most likely needs to be reapplied.
Reply 22 of 420, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Nope, it was definitely not hot-melt glue. Solid brown and porose.
1+1=10
Reply 23 of 420, by Malik
Just opened my MK-II now, and fortunately there was no leakage.
I changed the battery anyway, and the former battery was old enough to have the battery holder's top plastic retainer's impression on it's surface.
Reply 25 of 420, by Yawnald
Just wanted to bump this thread as a warning. I've never in all my years seen a leaky lithium cr2032, well, until recently that is... For some reason, this thread inspired me to open my 8 new in box Asus TUSL2 motherboards and check the coin cell batts for grins. 7 were fine (dead as can be), 1 was not! A leaky maxell cr2032! I've never seen this happen until now! Needless to say, I spent some time pulling coin cell batteries off of my shelved mobos after that... 😲
Mr. Tualatin
Reply 26 of 420, by Stefan_L
keropi wrote:
^ ah, so that's how the mk2 is inside... here's a pic of the mk1 for comparison 😁
And here is another MK1 😀
It's an old pic i did when i dumped the roms for the MESS project, the battery was fine though 😉
- Big pic here -
Reply 27 of 420, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
So... As I am about to reassemble my office with varios gaming addons... the battery is NOT needed for game music playback only for advanced programming, right?
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 28 of 420, by keropi
I have removed the battery from mine and notice no difference in gaming usage... the only change I saw was the "battery low!" message on the sc-55's boot up... since we are not using these units to compose music we don't care about custom settings/maps/whatever being stored on the unit 😊
Reply 32 of 420, by badmojo
Opened mine today and yes, the battery was starting to go. Thanks for the heads up!
Probably a silly question but do MT-32's have a battery?
Reply 33 of 420, by Great Hierophant
No, but people came up with MT-32 modifications to add a battery, so you may wish to check if you believe the unit you have or are planning to buy is modded. If your unit is Sound Canvas compatible and has a display, it is almost certain to have a battery.
Reply 34 of 420, by Soupdragon
Checked mine today the battery was fine but I removed it anyway just encase. 😀
Steam | World of Warcraft
Reply 35 of 420, by Mau1wurf1977
Just letting you know that the Roland SC-55ST doesn't have a battery inside.
While we're at it. Does anyone know how to open a Yamaha MU80 unit?
I removed a ton of screws but not closer to opening it.
Also what's a good source for these button batteries? Might buy a few in bulk.
My YouTube channel
Reply 36 of 420, by keropi
I opened mine to clean it, IIRC you remove the screws and pull the faccia with the screen... kind of tight but that's how you get it open... it has a soldered CR-2032 battery inside, no holder
Places that sell/repair watches also stock CR-2032 batteries, else it's places that sell electronic equipment components around here.
Reply 39 of 420, by carlostex
I just removed the CR2032 from my SC55. No leakage and very clean! Arigato Japan!!
