First post, by Stojke
- l33t
Did you not Google? The first hit for <"os/2 warp" smp> is http://www.edm2.com/0507/smp.html , which suggests you need a particular version of Warp 4.
See also http://www.os2museum.com/wp/?p=819 .
wrote:Ive tried at least 20 different search quotas. Only one mentioned that OS2 Warp 4 does not support multi cpu.
I'm confused. Does that not answer your question..?
I have an installation disk, two of them.
And do either of them say "Advanced Server, Symmetrical Multiprocessing" anywhere?
I was not sure its correct due to only it mentioning no SMP compatibility.
I have a much bigger problem on hand at the moment. The installer floppies dont recognize the SCSI controller, so i had to install it into the floppy medium. But even after editing the config.sys it still doesnt work. I have also tried switching to IDE but still the same, it "can not control" the devices.
I never messed with OS/2 - but I suspect there is a reason why it lost
I've spent 6 hours reading a whole lot of different documentation and trying at least 20 different approaches to installing it.
None has worked and every one failed to install.
Not to mention the pain of waiting for all those floppies to write data and format.
Even tried onboard IDE.
I mean, sure as hell i am not gonna install it over 140 floppies.
It's on FLOPPIES???????????????????????
Could you copy all those onto a CD?
