Windows, Doom, Apogee OPL3 Synthesizer.
First post, by nukeykt
OPL3 MIDI Driver for Windows.
03/04/2021 Update (by Wohlstand):
News:
Windows XP compatibility was been retured back
Added CMake build support
Added MinGW and MinGW-w64 compilers support
Added an ability to run the driver on Windows 2000 (maybe it will work in Windows NT4, not tested yet)
Source code is now moved to github: https://github.com/nukeykt/WinOPL3Driver
Big thanks to Wohlstand for this update.
Doom OPL
Games: Doom, Doom 2, Heretic, Hexen, Strife, Raptor
6/20/2016 Update:
News:
Doom 1 1.666 mode
Bugfix:
Operator volume calculation fix
Apogee OPL
Games: Rise of the Triad, Duke Nukem 3D, NAM, Blood, Shadow Warrior(Shareware).
OPL patches:
built in patch - ROTT 1.3, Build engine games setup utility.
apogee_blood.tmb - Blood
apogee_duke3d.tmb - Duke Nukem 3D
apogee_lee.tmb - ROTT 1.0-1.2
apogee_nam.tmb - NAM
apogee_sw.tmb - Shadow Warrior(Shareware)
Installation:
1. Install Visual C++ 2015 Redistributable.
https://www.microsoft.com/en-US/download/deta … s.aspx?id=48145
2. Install driver.
3. Install OPL patch (Optional)
OPL Patch installation:
1. Create OPLSynth folder in C:\ disk root.
2. Copy *.tmb files to C:\OPLSynth folder.
3. Copy needed tmb file as apogee.tmb
4. If you want to use built in patch remove apogee.tmb
Windows OPL
5/5/2016 Quick update:
Bug fix:
-Stupid bug in OPL3 emulator was fixed. Driver is reuploaded.
5/5/2016 Update:
News:
-Very accurate Nuked OPL3 emulator, which present in ZDoom and in development versions of Chocolate Doom!
-More accurate compared to Windows 9x SB16 drivers!
-x64 version!
Installation:
2. Install driver.
Reply 1 of 218, by leileilol
FINALLY, IT EXISTS!!!
THANK YOU!!!
EDIT: Noticed there's a strange pitch bend issue when playing fastway.mid (Rise of the Triad) around 1:37, the same bug i've heard in PCem in Win3.1's FM midi driver even...
Reply 2 of 218, by Stiletto
Ooh, I like virtual sound cards 😁
do the Fandango!" - Queen
Stiletto
Reply 3 of 218, by nukeykt
This bug also exists in Windows 95/98. Original FMSynth sample driver haven't this bug. So i added this bug.
Reply 4 of 218, by leileilol
Ah.
Reply 6 of 218, by nukeykt
Which error code ?
The code 10 means that OPL3 not found at 0x388 port.
Which CMI8738 chip's revision?
It seems to me that OPL3 exists if number of chip's revision 37 or less.
Which your PC's processor?
It seems to me that AMD processors don't allow to write on some ports.
Reply 7 of 218, by ik777
khokh2001 wrote:
Which error code ? The code 10 means that OPL3 not found at 0x388 port. Which CMI8738 chip's revision? It seems to me that OPL3 […]
Which error code ?
Never mind. Your driver really tries to access my card's port 388 and my card only generates noise.
(Edit)
Confirmed FM won't work even in windows 98SE. every dos application's setup find fm but no sound.
In pure PC-DOS 7.00, fought with c3dmix.com, perfect SB16 Digital and detected FM but no sound.
CANNOT HEAR ANY FM SOUND WITH MY DARN CMI.
Reply 8 of 218, by sliderider
When writing an emulator, it's ok to fix bugs in the original hardware. 🤣
Reply 9 of 218, by DracoNihil
How do you configure the usermode thing? I can't find the "UI driven application" mentioned in the readme...
EDIT: also hitting stop does not cause the driver to stop, I have to kill whatever process accessed it.
― Κυνικός Δράκων
Reply 10 of 218, by ik777
Let me know which CMI are you using.
LP chasis type? Trapezoid one with least parts? or Full sized one with digital output?
They looks much better than ebay. Audiotrak refused to answer about FM support. 😠
http://www.abko.co.kr/product/view.php?pid=17006&cid=1168
http://www.abko.co.kr/product/view.php?pid=17004&cid=1168
http://skyok.co.kr/?this_in=product_view&seq= … =37&view=hidden
http://audiotrack.co.kr/kr/index.php?mid=pci& … cument_srl=3727
http://audiotrack.co.kr/kr/index.php?mid=pci& … cument_srl=3724
Reply 11 of 218, by nukeykt
My soundcard:c media 8738 sx 4ch.
Also fm don't work on some pc. Try on another computer.
Reply 12 of 218, by nukeykt
Try this driver:
The attachment cmi.zip is no longer available
This driver for cmi8738 with integrated opl3 driver.Opl3 is working on CMI8738 IO Port + 0x50 port.
Reply 13 of 218, by ik777
khokh2001 wrote:
Try this driver:
cmi.zip
overwrite and DSEOed it in \system32\drivers. How can I check OPL3 works?
(I confirmed my card won't make any FM sound even in mixer in DOS, But SBPRO works.
In PEEKPOKE, PEEK C01A reports C8, POKE it 00 and 08 but 388 reports only FF.
The Adlib and compatible (fmsynth.inf driver) NEVER removed its yellow question marks itself as erroecode 10 in DM.)
Reply 14 of 218, by nukeykt
Sweet midi player
Reply 15 of 218, by ik777
Forget everything and decided to use user mode drivers. Old games as windows 9x's times supporting MIDI BGM works well.
I didn't tried but is it work with my ymf-724 in 32bit XP or later?
Reply 16 of 218, by MaliceX
Hi, I haven't posted here in a while but bumped across this post while looking for something semi-related to Adlib and MIDI.
Wow! Really awesome, thanks very much for sharing this to the web, khokh2001! I've always wondered when someone would eventually pull this off.
Currently testing this in Windows XP x64, 7 x64 and Win 8 x64, working great with the user-mode drivers. I do have a YMF724F-V PCI card which only works under XP, so I might give it a go with the kernel drivers.
Also big thanks for sharing the source code too. I'm actually looking into seeing if it's possible to switch the default patches with say, patches used from .ROL music.
EDIT: OK so I have attempted to install the kernel driver on XP where I already have the YMF724F-V legacy mode enabled with PowerYMF. Regardless of methods of installation (Add new hardware, update driver on Legacy Sound System which has port 388h used), I get the following:
An error occurred during the installation of the device.
The class installer has denied the request to install or upgrade the device.
Assistance is required. Thanks.
Reply 17 of 218, by DracoNihil
Any status on fixing the bugs in usermode driver so that stopping playback in Winamp actually tells it to shut down? It is rather annoying having to shut down whatever program accessed the driver before I stop hearing stuck notes.
― Κυνικός Δράκων
Reply 18 of 218, by MaliceX
How are you getting stuck notes? I'm using Winamp and I have no problem other than that I would occassionally need to reset the MIDI driver via a MIDI, or restarting Winamp to address pitch bends left over from the previous song (this is common with many MIDI drivers).
Reply 19 of 218, by leileilol
I just use Media Player Classic.
