First post, by DosBoxer
hi !
just installed DOSbox/w32 on a w2k machine (german version), now I noticed
that although most characters are correctly available, some characters
such as for example the backslash don't seem to be available in the DOSbox.
Off course this is a 'problem' regarding DOSbox's usability ...(think about mouting directories etc.)
I tried typing in these characters by using their respective ASCII codes:
to no avail.
Either I am doing something absolutely wrong or this is a bug.
I am now going to give it a try under Linux.
Reply 1 of 4, by eL_PuSHeR
NORMAL SLASH WORKS JUST FINE, SEE?
Reply 2 of 4, by Guest
oh my god ... thanks sooo much !
I didn't even try it, because I knew it doesn't work under DOS the way
it does under Unix.
DosBoxer
Reply 3 of 4, by MiniMax
Rank Moderator
Moderator
You did try to search, didn't you?
german layout
German DOSBox Forum
cant put "\" at dosbox
How do i get ~ symbol in dosbox?
Alt Gr does not work
problem with the keyboard
keymap support?
_________________
Reply 4 of 4, by Guest
Hi !
To a certain extent: yes.
Anyway, thanks for the links and hence the efforts 😉
Another idea I had while using DosBox: how about creating a
shell-extension, to enhance the context menu in Explorer/Konqueror...
to enable running a specific application with DosBox from within
the file explorer of the corresponding OS ?
It might even support different DosBox-Profiles/Configs.
Thanks so far !
DosBoxer
