VDMSound w/ kyrandia 2
First post, by GunStarHero
When i start up VDMSound DOS v.2.01 everything starts as normal. The sounds and music are all on time with the game. The music some times skips when i enter a different scene, this is a mild problem. The real problem is the sound effects, because the more i play the more they seem to shutter. The worse spot i have come across to demonstrate this is the lightening bug tree. When you get them to play the song it is horrible. The sound problem just continues to deterorate the more i talk to differant characters and i am unsure how to fix this situation. An important thing to note is that once it reaches a really shutter sound quality it will stop there. The quality will neither increase nor decrease from that point.
Processor: 3.0 ghz 800mhz bus/ w hyperthreading
RAM: 512 DDR 400mhz
Motherboard: Intel 875i w/ onbaord raid
Video: ATI Radeon 9800 Pro 256mb
Sound: Soundblaster Audigy 2
Harddives: 2X 36 gig 8mb buffer raided together
OS: Windows XP Pro
Reply 1 of 4, by Snover
VDMSound DOS? Version 2.01?
Yes, it’s my fault.
Reply 2 of 4, by GunStarHero
I don't know what i am talking about. I am relatively new to all this so bare with me on this one. I have whatever the lastest VDMSound version is and all the accompanyments. Does that clear anything up?
Reply 4 of 4, by Manias
Here's what you do: Get yourself the latest DOSBox (0.61 or something) and run it on there 😀 The latest version added protected mode games (dos4gw) i.e. kyrandia 2 (and 1 and 3 ) runs like a charm!!! No hickups nothing 😀
I tried that cuz for some reason vdmsound doesn't work on my computer at all. But that's another story 😊
You can get dosbox from http://dosbox.sourceforge.net
(Just a quick doxbox tip: When you've installed it run it and type "mount c C:\" or whatever hard drive you want to use. Then you can access your c drive and run kyrandia. If you've got more probz check out the dosbox threads on this same forum!)
Hope it helps 😁
