First post, by Parasite X
Ok heres my problem DosBox runs the game too sloooow and VDMSound runs it to fast but its very stable. Ive tested speedset and and moslo v1.32 but they dont work. If anyone knows of a good app that can be run on WiXP with VDMSound then plz add an link to where i can get it.
Reply 1 of 7, by eL_PuSHeR
Did you try advanced cpy options under VDMSound? Like Cap dos timer and try to reduce cpu usage?
Reply 3 of 7, by MiniMax
Rank Moderator
Moderator
> Where do i find this option??
With VDMSound v. 0.0.0.0.1 you had to use a screwdriver and open up your PC. Then you had to physically remove the third resitor from the left, for the option to appear. In version 7387.6 it will probably be integration into the O-Magic-Thing-Cap interface, so you will just have to think about the option and it will appear.
Since you do not tell us which version of VDMSound you use, it is hard to tell you where *you* can find this option.
_________________
Reply 4 of 7, by Guest
yeez no need to be snappy. Im using the latest verion 2.0.4 something.
By Advanced cpu option do you mean im supposed to underclock the cpu in the bios or what. Its not like it written in plain sigth in the vdms readme.
Reply 5 of 7, by Parasite X
Nevermind, noticed there is an add-on launchpad program where you can change this stuff.
Reply 6 of 7, by Parasite X
Bah, didnt even scratch the performance even an inch. guess my cpu is jus to damn high (athlon xp 1800). Guess ill jus havta dig out my old pentium from the backyard.
Reply 7 of 7, by Snover
Or just use DOSBox.
Yes, it’s my fault.
