First post, by BattleZealot
I´ve searched the forum and found some threads about this, but not quite what I´m looking for:
I want to use an old DOS based Robot automatization simulator program from 1995. (Won´t start under NT based Windows OS)
The program won´t start without a hardware lock, the lock is a parallell port dongle.
Is there a way for seeing this paralellport in DosBox? Maybe a patch or similar?
Maybe USB-TO-Parallell port converter? Config file to that?
Thanks in advance!
