First post, by ratfink
I have a 32 bit application in mind for my work, which would be run under 64 bit windows.
Aside of limitations deliberately built into the software itself, is it going to be limited to the max memory that 32 bit addressing can see [3.5gb or whatever] or would 64bit memory limitations apply? I have datasets that could come to 12gb, and the application is designed to run with them loaded into memory.
Anyone know?
Reply 2 of 3, by ratfink
Ok thanks, that was enough to get me started. From what I can see, a 32 bit application would be limited to a maximum of 4gb even when run on a 64 bit version of windows with plenty of memory.
Reply 3 of 3, by gerwin
I see differing info on the net. Microsoft says this about it:
http://support.microsoft.com/default.aspx?scid=889654
General memory limits           32-bit OS               64-bit OS
Total virtual address space 4 gigabytes (GB) 16 terabytes
Virtual address space per 2 GB, 3 GB if the 2 GB, 4 GB if the application
32-bit process system is booted is compiled with the
with the /3GB switch /LARGEADDRESSAWARE switch
Virtual address space per Not applicable 8 terabytes
64-bit process
