First post, by kumijorma
I have used MT-32 emulation for some games with DOSBox and it worked fantastically with 0.74.
After installing SVN Daum Build 02052013, I noticed that MT-32 emulation did not work in the following games:
- Accolade Summer Challenge
- Accolade Winter Challenge
The attachment DOSBox Error.JPG is no longer available
So, I decided to update my SVN Daum installation to 07252013 and had another look.
- No luck.
Then I read that Munt had come around. First thing I did was to set things properly: setting "mt32" as midi device via config file and placing ROMS to the root folder, because it was told that Munt was included in the SVN Daum.
- No luck, but MT-32 emulation was working with other games perfectly.
I even tried to install Munt separately.
Then I looked at the console output with Munt installed separately or just DOSBox set up properly.
- Yes, MT-32 was initialized.
Then I came here and read the rules. I needed to confirm this problem with a Vanilla Build, so I tried EmuCR Dosbox r3833.
Just to make sure, I tested official 0.74 again:
- Perfect.
My conclusion is that something has gone wrong, since Vanilla Build has the issue just like SVN Daum has.
New Builds has some improvements with MT-32 emulation. Forumula One Grand Prix (Aka World Circuit) can finally output the car sounds when MT-32 has been selected via Installation. Crashes are not heard, though. Official 0.74 will only output strange whiny and belly sounds for F1GP if MT-32 emulation has been used.
Reply 1 of 3, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Did you adjust the config files of both daum and lock stock SVN built? They are both NOT using the config you set up for 0.74.
and can you describe "not working"?
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 2 of 3, by bloodbat
Try lowering the cycles, MIDI code has changed on the latest SVN code and some games refuse to acknowledge MIDI devices if set too high (Day of the Tentacle comes to mind)
Reply 3 of 3, by kumijorma
Yes, like I said, for other games supporting MT-32, everything went perfect.
Thanks! That did the trick. Now I can hear MT-32 MIDI on both games again. (Forgot to say that with higher cycles, Sound Blaster MIDI worked normally.)
