SB 2.0 CT1350 CMS chips dumped
Reply 300 of 468, by bristlehog
I am totally new to flashing, and its somewhat scary to blow something. What should I do with all this?
Common sense says that steps should be like that:
- Insert a GAL chip into a programmer
- Run the software
- Plug the programmer into USB port
- Select the chip type (GAL16V8a)
- Load the JED file
??? can't imagine what's further
Hardware comparisons and game system requirements: https://technical.city
Reply 301 of 468, by keropi
^ ??? can't imagine what's further = press burn/program button
- verify content of chip
- remove chip
- unplug programmer/turn of computer whatever you want
- use chip
that's the general idea of programmers, also you don't need to insert the chip before connecting the programmer, you can have the programmer connected and insert/remove chips as you like
Reply 302 of 468, by 133MHz
I remember reading on the G540 manual (in wonderful Engrish) that you shouldn't leave a chip in the programmer when connecting or disconnecting the programmer from the USB host - the pin drivers start in an unknown state at power-up and could be putting out erroneous voltages before they stabilize, so device insertion/removal should only be done with the programmer fully powered up and ready. It goes against the "hot-plugging is unsafe" wisdom but it makes sense.
By the way I've found out through experience that this programmer is very sensitive to the build quality of the USB cable you're using. Cheap cables have given me false connection errors and general erratic behavior which completely go away when using a better USB cable.
http://133FSB.wordpress.com
Reply 303 of 468, by bristlehog
That's what I get when trying to program my NS GAL16V8A with SB2CMS.JED posted by DonutKing:
What am I doing wrong? I haven't found any switch to remove the chip write protection (if there's any). The only one 'unprotect' option in G540 software is greyed out:
Reply 304 of 468, by DonutKing
From memeory I think I had success if I went into the Set menu and changed the program sequence to remove the Encrypt step.
Looks like you're running win 8, I never got mine working on anything newer than XP.
Reply 305 of 468, by carlostex
Remove the encrypt because it makes the data unreadable. That's why it gives a verify error. If you remove encrypt and you have the same error then you are facing a defective GAL. Try another one. But always remove encrypt from the program sequence.
Reply 306 of 468, by bristlehog
I have removed the Encrypt step, but to no result. Nothing changed either when I took another GAL chip.
Reply 309 of 468, by carlostex
It's not loading the FUSEMAP properly dude... That won't work. I had that problem too, and i had to tamper with the file. You can also try to put the numbers there carefully, opening the JED file with notepad, and put the 1's in the correct places.
Or you can wait until tomorrow, i'll upload you my modified file that will work.
Reply 310 of 468, by bristlehog
I'll wait tomorrow, since anyway I don't have the hardware to test SB 2.0 with me here.
Reply 311 of 468, by DonutKing
Try deleting any comments at the beginning of the jed file. I think I had problems with that too.
Reply 312 of 468, by carlostex
Ok bristlehog, try with this file i've just attached. Make sure the encrypt is out of the programming sequence. It has a nasty habit of coming again.
Good luck!
    TEXcms.rar
    297 Bytes
    144 downloads
    JED file for SB2.0 CMS upgrade
Reply 313 of 468, by bristlehog
Oh well. The fuse map now looks correct, thanks to carlostex's JED-file. But I continue getting verify errors:
I have read the GAL contents into a buffer though and it looks same with JED-file fuse map. Maybe it is burned correctly despite the verify error. I have to test the GAL against SB 2.0 I think.
Reply 314 of 468, by carlostex
Yeah you need to try the GAL's. Exit the software and then run it again. The first thing you must do is to read the GAL. If the DATA reads the same values as the file then it should be OK. If not the GAL's are fucked up and you need new ones. Try Lattice. They will work the same.
Reply 315 of 468, by bristlehog
Yes, the GAL reads back values that appear to be correct (I am way too lazy to thoroughly compare all of them).
Reply 316 of 468, by carlostex
Then all you need is a card to test.
Reply 317 of 468, by bristlehog
Hearye, hearye! To all brave an' loyal dwarves!
My 059316 revision card seems to be working ok. I hear CMS from Codename:Iceman, and SB PCM/Adlib music from Warcraft 2. No time to do further tests for now, but I will do it in future.
Sorry for being so lazy and procrastinate it till nowadays. Big thanks to carlostex who greatly helped me with GAL flashing.
Reply 318 of 468, by carlostex
Glad you got it working.
BTW, does your 059316 revision card sport the CT1336A bus chip?
Reply 319 of 468, by bristlehog
Here's my card and it for sure has DSP v. 2.02 and CT1336A bus chip. The reason for other cards' failure must reside elsewhere.
