First post, by soviet conscript
- Oldbie
been using an mt-32/sb16 setup on my 66mhz 486 and its mostly worked fine for the past few years but recently got a hold of a mpu-ipc-T isa card as well as a mpu-ipc breakout box and wanted to replace the sb16 with a true roland card. problem is after doing this all I get is random sounds. when i engage the turbo feature and slow the PC down a few games like Fate of atlantis works fine but quest for glory 1 is still a jumbled mess of sounds. I played around with it for a few hours to no avail so went back to my mt-32/sb16 setup. is my pc just to fast for this card? i'm guess my only option is one of the hard to find mpu-401AT cards?
