First post, by emuola
Hi.
Just started experimenting with my "dream dos-machine"... Here are the specs:
P200MMMX
32MB ram
4Gb flash ide hd
SB16 Value
Diamond Stealth 1MB Dram
3com nic (fot transferring files between dos-machine and pc)
Roland CM-500, in A-mode (CM-32L etc) (hooked up to SB16 with a midi/joystick y-cable)
DOS 6.22
I tried LL3 and the intro music sounds like a bunch of loonies playing some real wacky stuff. Wrong instruments/notes. I know the module should be able to play the music right, but something's clearly wrong. For example music plays fine in 4D sports boxing with the MT-32 option, but occasionally I hear a piano note?! when I hit the other boxer...
Is this a known problem? What have I misconfigured? Could it be the cable? I cannot test with a "non-y-cable") at the moment.
