power question
First post, by ncmark
Hey everyone - I have a power question. I am running an athlon 2400XP with a radeon 9600 and 1-gigabyte of DDR RAM. What power supply would be adequate?
I am currently running it off an enlight (came with the case) 230 watt supply. Although it has not been giving me any trouble it seems a little small. I am decommissioning another computer that actually has a better supply (pc power and cooling silencer 370) and was contemplating swapping them out.
On the other hand don't fix it if it ain't broke 🤣
Reply 1 of 5, by Forevermore
Enlight is a pretty good brand. So 230W is at least an accurate claim. I personally would go with a high quality, period correct 300w unit for that setup.
So many combinations to make, so few cases to put them in.
Reply 2 of 5, by ncmark
Thanks for the reply - I'm kinda inclined to leave it alone unless it becomes a problem. I don't think the system is really all that power-hungry....
Reply 3 of 5, by swaaye
That is probably an adequate amount of power. Radeon 9600 is quite low power (it doubles as a notebook chip). That Athlon XP is around 50W max. Not much power in general going through that machine.
Reply 4 of 5, by KT7AGuy
By way of comparison, I ran the following system as my HTPC for 7 years of moderate use with no issues whatsoever:
ABIT KV85 Socket 754 motherboard
Sparkle 270W PSU
Athlon 64 3400+ Venice (2.4ghz)
Thermaltake Venus 7+ CPU Cooler
1GB Crucial RAM (Two 512MB sticks)
Radeon 9600XT AGP
Two IDE hard drives
One IDE DVDRW
One PCI WiFi adapter
One PCI ATI HDTV Wonder
One PCI Chaintech AV-710 sound card
Two 60mm rear fans
One 80mm front fan
Please consider:
My Sparkle 270W PSU is probably comparable to your Enlight 230W PSU.
I was running two IDE hard drives, three PCI cards, and a 9600XT.
I assume that your 2400+ and my 3400+ consume about the same amount of power.
Your 9600 will consume only 15W, max. My 9600XT consumed only about 25W, max.
The old 9600 series Radeons were very low power and low heat video cards. However, they provided a pretty good level of performance. They were perfect for HTPCs (circa 2006), in my opinion. In fact, I removed the HSF from mine and installed a totally silent Zalman ZM50-HP passive cooler. I never had any problems.
I think you're gonna be just fine with the system you have. You can probably upgrade to a 9600XT without problems, but I wouldn't push things beyond that.
If you have problems, you know that your PSU is the first place to start troubleshooting. In that case, you should swap with your spare 370W PSU to see what happens. If you need a new one, Rosewill makes a pretty nice 350W PSU with a strong 5V rail for your Athlon XP for about $30. I use one in another box of mine that runs an Athlon 1400 and Voodoo 5. I have no complaints and would recommend it if you have problems.
Reply 5 of 5, by ncmark
One of the reasons I like the radeon 9600 cards (I have three) is that they do NOT require a cooling fan. Also, that is just about the latest card for which you can still get Windows98 drivers 🤣
