First post, by mr_bigmouth_502
- Oldbie
Whenever I try mapping the controls for it in certain emulators, it thinks that I'm holding down one of the axises so I can't properly map my controls. The funny thing is, it varies from program to program, as I have this problem in Project64, Xebra, and NullDC, but not in VisualBoy Advance, Higan, or PCSX-R/PCSX2. I made a short video so that you can see what's happening: http://youtu.be/zvyo5OaQFX0
Does anyone know the cause of this problem or how I could fix it? I'm using the 64-bit XP drivers available here, http://lavendy.net/special/driver/x360c/index.html though I've also had a similar issue with these drivers back when I was on XP 32bit. http://vba-m.com/forum/Thread-xbcd-0-2-7-rele … -be-posted-here Granted, back then the only times I had issues were with Xebra, and occasionally with Dolphin.
EDIT: Holy crap, I actually found working drivers. 😁 It turns out there is a 64-bit XBCD driver, I just had to look for it. I found mine here: https://www.youtube.com/watch?v=e-CqvgnAV80 Basically, what you have to do is install the XBCD 0.2.7 drivers normally, then replace the driver files it provides with the ones in the 64bit zip file.
