Virge GX2 AGP
First post, by Amigaz
Have one of these cards
http://www.tradera.com/Grafikkort_S3_Virge_GX … uktion-58110407
Thinking of using it in a super socket 7 mobo I have but not sure how good it is for DOS games + have any good VESA support..
What do you guys think?
Reply 1 of 6, by swaaye
S3 ViRGE usually works out ok because S3 hardware was so popular back then. You may want to get S3VBE and S3SPDUP to fill out their VESA capabilities if you have problems or major speed issues.
Reply 2 of 6, by Silent Loon
You could also give this card a try:
http://www.xbitlabs.com/articles/video/display/savage4.html
It has the S3 Savage 4pro GPU, which might be a good choice if you want to use your machine with Win98 and early 3d-games too. It is pretty fast (compared to a Virge "3d-decelarator") and supports S3TC (texture compression) natively which looks nice in Unreal. I used it for a while, and it seemed to me as if S3 didn't change much regarding the dos/ VGA / vesa features (it seems the same as the Virge core) - in any case I had no problems with it in DOS.
Reply 3 of 6, by bytesaber
Does a GX2 on an AGP bus work for early DOS 3d games? Does a Savage like this work for the "s3d" games?
Reply 5 of 6, by leileilol
A bump in an emulation forum?
Reply 6 of 6, by bytesaber
My fault. I found this while Google searching, and did not look at the hierarchy of the forum before posting.
