First post, by Kreshna Aryaguna Nurzaman
- l33t
I understand GeForce 6800 is the latest (and fastest) video card that supports Windows 98. I don't know if Radeon X800 also supports Windows 98, but even if it does, GeForce seems to have better FSAA compatibility (this and this). Among those who have been successfully run Windows 98 with GeForce 6800 is Malik, and the video card runs without problems.
Now, my question is: what would be the best system for Windows XP? Video card will be the primary consideration here. As such, the system will be built around the video card in question.
(1) probably some people will point to GeForce 8800, but I aim for the latest video card possible. I wonder if GeForce GTX 590 will work on XP, or how about Titan?
I could care less about features related to DirectX10 and above. My goals are highest fill rate possible and highest quality FSAA possible for games that run on XP. Games like MDK, Neverwinter Nights (note: the game is problematic on Windows 7, which only motivates me further to build the ultimate WinXP machine), Freedom Force, Crimson Skies, and Enemy Engaged series. Certain games like MDK works well with Windows 98, but it will be limited by GeForce 6800's fill rate. While the video card is fast enough for 640x480 games like MDK, I wonder if I could boost the frame rate and FSAA even further.
Also, I'm really tempted to test new FSAA technologies on old games running on Windows XP, especially "2D FSAA" like FXAA (which works well on "2D" games like Comanche 3).
Another "must-have" feature is SSAA. While MSAA is faster, it is problematic with older games. As such, the video card should still support SSAA. Yes, SSAA is slower, but I'm going to play older games anyway, so the slower method of SSAA will be compensated by tremendous fill rate of the video card anyway.
Based on the criteria above, what should be the best video card for my purpose above? What is the latest video card that still runs on Windows XP, while still supporting SSAA method, and also supports new AA like FXAA or TXAA? Should I go with Radeon or GeForce? I heard that Radeon cards support SSAA again since Radeon HD 5xxx and above, but is it "true" SSAA? Is it compatible with older games?
(2) The second consideration is EAX. The system will have the best EAX card available (either Soundblaster X-Fi or ASUS Xonar DX). As such, the motherboard should have available slot for the said sound card. What motherboard will be best for the purpose? What motherboard fulfills the following criteria?
- has Windows XP drivers
- accepts the fastest video card possible for Windows XP as described in point #1
- has quite plenty of PCI/PCIe slots for EAX sound card
(3) the last thing to consider is CPU. While I'm looking for the fastest video card possible, I'm actually going to put the slowest CPU possible on the system, and here is why.
On my B460 laptop (the latest laptop with GeForce chip that still support Windows XP - no stinking Optimus!), I always get the feel that the CPU is too fast while the GPU is too slow. It is pretty notable in Crimson Skies, where I notice choppiness in heavily-textured scenery (GPU is not fast enough), but the roll rate in certain aircrafts like Hughes Bloodhawk is way too fast to handle (CPU is too fast). Based on the games I mentioned above (Crimson Skies, MDK, etc), I don't think I would really need a fast processor. Even i3 maybe sufficient, or I may go for AMD instead. What I really need is video card with humongous fill rate and best FSAA compatibility.
So, what should be the best recipe to built the system described above? What video card should I use? What motherboard should I use? Should I get GeForce or Radeon? Should I go with Intel or AMD?
Thanks.
Kreshna Aryaguna Nurzaman.
