First post, by GeorgeMan
- Oldbie
Guys, I need your help!
I just finished installing DOS 6.22 and Windows 3.1 on an old 486 machine. But I have problem with a SoundBlaster Vibra 16S PnP.
I run the CTCM (config manager) from a floppy, it finds my card and sets the blaster variable for the non-PnP dos& windows 3.
I then insert the 2 floppies and install the drivers. After the soft reboot everything works good, I even installed windows 3.1 from the card's IDE and have sound in both dos and windows.
BUT!
After I power down the machine, it cannot recognise the card and of course I don't have sound and cd-rom support.
If I delete the entries in autoexec.bat and config.sys, soft reboot, and redo the procedure, everything is ok until the first power down.
What am I missing? What am I doing wrong?
Please help! 😢
PS: I remember me doing this exact thing a few weeks ago and everything was working as intended...
HP Elitebook 14 G1a | Snapdragon 12core | 32GB LPDDR5X RAM | Adreno GPU | 32" AOC 75Hz 2K IPS + 17" DEC CRT 1024x768 @ 85Hz
Windows 11 on ARM --> pcem ARM | Eden & Dolphin ARM editions
