First post, by lucky7456969
When I capture the screen, the dosbox becomes invisible (closes)
I have to restart it. Especially in ykhwong build after
I made several modifications to it. The modification
involve changing the fonts to 0.74 ones and block out
some devcon.h code for ansi.
I can't attempt to enter unmounted drive because
the mount command is trashed.
Thanks
Jack
Reply 1 of 1, by Qbix
Rank DOSBox Author
DOSBox Author
it works fine in normal dosbox.
Water flows down the stream
