DS12887 drop-in replacement
First post, by Maeslin
While waiting for parts to arrive for another project, I've begun designing a drop-in replacement for the infamous integrated-battery DS12887 / M48T86 RTC/NVRAM package.
It's pretty much a small-package DS12885 mounted on a small adapter board with the clock crystal and user-replaceable batteries (probably a pair of LR44/SR44 due to space constraints) that would fit inside the footprint of an existing DS12887 package and drop right in the socket, no alteration required.
If there's interest, I might make a small production batch.
Reply 1 of 175, by Mau1wurf1977
http://www.ebay.com.au/itm/130810136997?ssPag … 984.m1497.l2649
But use a socket so it can be easily replaced again.
My YouTube channel
Reply 2 of 175, by Maeslin
I know the DS12887 is still around, I just find it annoying to either have to replace the whole package or crack it open and frankenstein a new battery in there. :p Plus, when you buy a DS12887, you never know quite how old it actually is. The battery could already be near-dead.
What I intend to make will be a drop-in replacement for it, but with easily accessible and replaceable batteries while still fitting in the same volume. I'm just wondering if anyone else would be interested by that. 😀
Reply 3 of 175, by Old Thrashbarg
I really don't understand the resistance to the idea of alternatives, but every time the subject of Dallas chips comes up, there's always a few who insist that you should just buy a new one, as if there are no disadvantages to doing so.
I personally think a drop-in unit with easily-replaceable batteries would be fantastic.
As for the design of the thing, rather than two LR44 cells, what about a CR1220/CR1225? Those are about 1MM larger diameter than an LR44, but they're thinner, plus they're 3V so you'd only need one of 'em. A little bit of toying around with the layout, and you may even be able to make the whole unit a bit thinner than a Dallas chip... which really wouldn't be a bad thing, considering the awkward locations they sometimes inhabit.
Reply 4 of 175, by Mau1wurf1977
Because such an alternative is not an alternative for many. Most people don't solder and aren't into modding, don't have the tools...
Now if such a product would be available on eBay, sure people would happily buy it.
If you don't understand the resistance then you don't have an understanding of potential customers.
Maeslin:
Does your solution still require de-soldering the old chip?
How much would you charge for a unit considering all the parts and time to build?
My YouTube channel
Reply 5 of 175, by DonutKing
Plus, you buy a DS12887, you never know quite how old it actually is. The battery could already be near-dead[
They have a date code printed on them. I bought some from ebay that were only about a year old.
Reply 6 of 175, by Maeslin
Old Thrashbarg wrote:
I really don't understand the resistance to the idea of alternatives, but every time the subject of Dallas chips comes up, there […]
If the old DS12887 soldered on the board, then unsoldering it would unfortunately be necessary. I've only ever seen them socketed to be honest. Soldering a fixed-lifespan component is just a dick move.
I've considered the CR1220/1225. They might fit but they have pretty much nothing for capacity. ~30-50mAh instead of ~200 for the CR2032s. That's where the LR44/SR44 would shine since a pair of them should give roughly the same lifespan as a CR2032. It's also a question of how easy it is to find each kind of cell. Going for a very common one makes things simpler.
It's only a vague cost estimate but $10-$12 plus shipping might be doable (sans batteries). Perhaps a tad more for the very first batch. I've already got most of the PCB designed and parts selected, just need to pick a battery format / matching holder and make everything as small as I can.
Reply 7 of 175, by Old Thrashbarg
Fair enough. But also remember that you don't need much capacity for this application... the battery current draw on the DS12885 is rated at 0.5μA. Even a 30mAh battery would be good for several years.
Availability I'm not so sure about, though. A lot of watches use the CR1220/1225, so the batteries themselves are pretty easy to get around here, but I don't know if that applies everywhere in the world. And I've never tried to buy a holder for one, so I don't know how easy it is to get those, nor how much it would cost.
Anyhow, it's not like I'm trying to push the idea. I just figured it was a thought worth mentioning, in case you hadn't considered the option.
Incidentally, it's got me wondering now... any idea what sort of battery they use in the DS12887? I know it's some sort of button cell, but I've never chipped one apart far enough to see exactly what it is, and I can't find it mentioned anywhere in the datasheets.
Reply 8 of 175, by Maeslin
Point, the CR122x would last for a LONG while.
When I tore a M48T86 in half, the cell inside was either a CR12xx or a CR16xx. Going for either might just be enough after all and their holders are much lower profile than what I'd have to use for 2x LR44s. I'll look into it and possibly post a rendering in a few days.
Reply 9 of 175, by feipoa
If my opinion has any value, I personally think such a replacement RTC is a pretty decent idea. I like the clean look of this proposal; I have never really cared for the the look of the semi-popular RTC mod with the battery atop the RTC. The battery in a Dallas 12887 typically lasts 15-20 years. I don't particularly care what style battery you select for your mod provided that it can last at least half the time of the old Dallas 12887's.
Reply 10 of 175, by Mau1wurf1977
When ever you do costing, take the number you think it will cost and double it 😀
The big hurdle for most will be de-soldering the old one and installing the socket.
My YouTube channel
Reply 11 of 175, by Maeslin
You probably wouldn't need a socket for the new one since the battery will be replaceable. 😜
It's a shame the pins aren't as prominent on the 12887 as they are on a DIP package. If it was the case it would have been possible to just snip the pins right at the package, drop the (pin-less) replacement between the stubs and solder them in place.
edit: Just realized, there's a slightly newer alternative to the 12885 that both includes a trickle charger (for rechargeable battery or supercap) and is about half the price of the original DS12885. Might end up going with that and recommending the use of a ML1220 (rechargeable 1220 variant) if there are no objections. The ML1220 would still be in a holder, not soldered or on tabs.
edit2: Here's an early render. Everything's there, the only thing missing are the pins. So far it's only ~0.180" high so there's plenty of room left. The regular DS12887 is between 0.300" and 0.330" high.
Reply 12 of 175, by feipoa
Just the term "rechargeable" might remind too many people of those leaky 386-era barrel batteries. The term alone might be enough of a deterrent for sales, leaky or not. Are you sure you want to use a rechargeable battery?
Reply 13 of 175, by Mau1wurf1977
Got a few Dallas replacements today. Can the battery voltage level be measured from the pins? Or is opening them up the only way.
Unfortunately I haven't got the sockets yet, so I will wait for these first.
My YouTube channel
Reply 14 of 175, by Maeslin
Wouldn't be much of a choice if I go with the newer DS12R885. The inbuilt charging circuit would cause problems with primary cells. I'll see if there's enough room to fit a protection diode but that would slightly lessen the lifespan of the battery due to the voltage drop.
If it's any consolation, the rechargeable cell used in this project is a tiny lithium one instead of the messy NiCads that were used on 286s and 386s.
On the other hand, the design and circuit is identical for both the 12885 and 12R885. The only thing that changes is the trickle charge present on the battery terminals, so making either variant is just a matter of picking a chip and associated battery.
Reply 15 of 175, by Mau1wurf1977
CR2032 gets my vote. Every supermarket sells it 😀
My YouTube channel
Reply 16 of 175, by Mau1wurf1977
Got my de-soldering station today. I practices a little on a new board and didn't have much luck. But it worked really good on the 486.
Here is the nasty ODIN chip removed 😀
Original: http://i.imgur.com/rEMNXx1.jpg
My YouTube channel
Reply 17 of 175, by Maeslin
If you have calipers, could you measure the height of the chip you just removed? I might end up replacing the battery socket with a top-loaded model due to space constraints (jumpers, other chips & co around the DS12887s)
Reply 18 of 175, by Mau1wurf1977
Using a ruler I measured 9mm!
I think a top loaded option would be a good idea.
My YouTube channel
Reply 19 of 175, by feipoa
You can get all this information from the datasheet. See attachment.
I hope you find a way to keep the battery internal to the unit.
    72.29 KiB
    No downloads
