First post, by adel
I just started getting this strange issue completely out of the blue where my keyboard gets stuck (it repeats whatever input I had held down) after about 30 seconds of using DOSBox, and the only way to fix it is to alt-tab out and refocus the window.
I've tried my best google-fu and I found a lot of people with similar problems but none of the things they suggested seemed to be solving my issue. It happens regardless of game, in fact it even happens if I just boot up dosbox with no game loaded. It's also worth noting that when this happens, the window still seems to be in focus (I can still use the mouse perfectly fine, ctrl-f10 doesn't help) but no new keyboard inputs will go through (not even alt-enter to exit fullscreen or other dosbox functions like changing CPU cycles). Even a fresh install didn't fix the problem.
Any idea what could be causing this? Dosbox worked perfectly fine on this PC until about last week, when the issues started popping up.
- BIOSTAR Group B75MU3+
Intel Core i5 3570K @ 3.40GHz
8.00GB RAM DDR3
NVIDIA GeForce GTX 760 (4095MB)
Realtek HD Audio
Windows 7 Premium
