Huge 286 tower found
Reply 20 of 37, by Half-Saint
It's actually ridiculous. I have no idea why they decided to stick a 286 inside a big tower and I also don't understand why the tower is sporting this huge power supply, normally used in desktop cases.
Reply 21 of 37, by Stiletto
Half-Saint wrote:
Added pics. How do you make the inline photos visible without having to click on the link?
It's a feature of this forum which was forgotten to be re-enabled after the forum upgrade. Admin (Qbix, etc.) has to fix it.
do the Fandango!" - Queen
Stiletto
Reply 23 of 37, by Half-Saint
vetz wrote:
Just add the code: […]
Just add the code:
[attachment=0]FILENAME.jpg[/attachment]
I tried that already and it didn't work.
Reply 24 of 37, by vetz
Half-Saint wrote:
Just add the code:
You attatched the files as well?
Might be some resolution restriction. I got it working in this post:
Re: Tomb Raider. Which version is he playing?
Reply 25 of 37, by Half-Saint
Resized to roughly 800x600 and it still doesn't work...
The attachment SB_Vibra.jpg is no longer available
Reply 26 of 37, by sliderider
Nahkri wrote:
Did a 286 really need a huge case like this 1?
A huge tower like that would be of little use unless you are building a professional system with a lot of drives installed like a workstation or server. A simple desktop or mini tower is enough for a period gaming rig. I'd rehouse the 286 in a smaller case if it was mine and save the full tower for a more extreme build.
Reply 27 of 37, by luckybob
Oh my... That case is ~GLORIOUS~. Also, that backup battery is the largest i've seen.
Reply 28 of 37, by cdoublejj
back in the day... waayyyy back in the day. when electronics were getting smaller, they would make big huge cases and instal metal weights. back then people didn't understand chip shrinkage and though bigger was better so that's what they did... made them bigger. 🤣
you gonna put any heat sinks on those VRM transistors?
Reply 30 of 37, by Half-Saint
Thanks for the comments.
I have no idea what to put inside this case at the moment. Don't know how any of my systems would benefit from a large case. None of them have more than one hard drive and the case has no 3.5" slots..
What VRM transistors? 😀
What's interesting about this motherboard: CPU is a Siemens 286-16 while the LED display is showing 10 when turbo is ON and 16 when turbo is off 😁
On the other hand the coprocessor is a 287-10...
Reply 31 of 37, by luckybob
10mhz is a "proper" speed for a 287. They are designed to run at 2/3 cpu speed.
Reply 32 of 37, by Half-Saint
Ah didn't know that, thanks for the info!
Reply 33 of 37, by Half-Saint
I ended up adding a 3.5" floppy and a CD-ROM (which of course doesn't work properly)... now, if only I could make this work 😀
Reply 34 of 37, by pianoman72
Try using the vide-cdd.sys driver. It works on my 286 CD-Rom drive.
Reply 35 of 37, by Half-Saint
Wow, that actually did it! Thanks a bunch 😀
Reply 36 of 37, by pianoman72
Awesome! Glad to have been of help.
Enjoy!
Reply 37 of 37, by Half-Saint
OK, after some research I found that the motherboard is OCTEK Fox-something 😀
Looks like you can't use SIMM and DIP memory at the same time. The previous owner skilfully broke two of the retaining latches so now the SIMMs are popping out from BANK 0, making it unusable. I might end up getting some replacemet SIMM sockets to fix the board.
