First post, by 3803
Would it be possible to add in an option into dosbox that's adjusts the cycles automaticly? I know this might be hard since best results with this might vary from game to game...
And a second thing...I'm aware of the workaround for foreign keyboards (using the / instead OR change settings in the control panel)
However, I have found this to be tedious at times so is it possible to implement keyb.exe (or com, dunno)
It would seem weird to me that this feature hasn't been considered yet.
Is there a reason why KEYB isn't used in dosbox?
Thank you 😀
