SB wrapper/bridge?
First post, by Unregistered
Are there any wrappers/bridges for SB cards?
I just wonder why Creative didn't undertook the development of such a feature.
For me it's ridiculous having to have both DOS and Win2k on the same machine to have the pleasure of playing some good old titles.
Reply 1 of 4, by Stiletto
Not to tick off Vlad, but the only application I have heard that will do something like this is SoundFX 2000. It will (as far as I have read) redirect YM3812 (OPL2) - aka Adlib - commands directly to the OPL2-or-compatible-or-emulated chip on your sound card. But that's all it does it for.
You can get SoundFX 2000 here: http://www.softsystem.co.uk/
However, why do that when you can use VDMSound's much-more-accurate emulation?
http://ntvdm.cjb.net
do the Fandango!" - Queen
Stiletto
Reply 2 of 4, by vladr
Actually it also does the EMU8k/EMU10k (whichever) that some games/trackers can use for custom MIDI wavetable synthesis + DSP effects. Registered version onky. 😀 But then again, GIVEIO.SYS does the same thing (although it efectively disables VDMSound as well).
In any case, why would you want a wrapper for SB?! The only reason(s) why VDMSound does not work with some games is independent of the actual SB emulation (in 99% of the cases it's some sort of Windows bug). And a "wrapper" would also require exclusive access to your soundcard (which means you wouldn't be able to use your soundcard while a DOS game is playing, e.g. for audio e-mail notification). So I really see no point in wrappers/bridges, it's more effort for less return -- why even bother thinking about it?!
V.
Reply 3 of 4, by Stiletto
Side topic:
One cool thing you could do, as a registered user, Vlad - is a feature comparison chart between the demo and registered version of SoundFX 2000 and VDMSound. Interested, Vlad? 😀
Stiletto
Reply 4 of 4, by vladr
Stiletto wrote:
Side topic:
Registered user? Of what? SoundFX?! Ha! 😀 No, the stuff about the EMU is in the SFX2K README. Don't have the thing myself and wouldn't personally care for EMUxxK emulation.
V.
