Unit Z:? Help!
First post, by DsC
Hi, my DOSBox only detect a Unit Z:, and onli contain Command files. i don´t have a unit z: but... Im uses Windows XP, help please
Reply 1 of 2, by Daniil
This is normal behavior, try "mount c c:\" command in dosbox 😀
(And read the docs, they're short)
/dev/brains: no such file or directory
Reply 2 of 2, by Guest
well i had the same problem. i mounted the drive c successfully with the command "mount c c:\". the first time i called the directory with the dos "cd" command and i saw the contents of my harddrive. that was ok. but the second time i used doxbox, the mounting was successful, but i couldnt change to the c directory anymore... i dont know why... who can help?
