First post, by lucky7456969
Under dosbox, the line with the tlink command rejected and saying the command line is too long.
How can I compile my little demo?
Thanks
Jack
ass2 : ass2.obj dragon.obj
tlink -v -LD:\Borlandc\lib ass2.obj s2.obj s3.obj s4.obj s5.obj s6.obj s7.obj s8.obj s8a.obj s9.obj s10.obj s12.obj dragon.obj graphics.lib
ass2.obj : ass2.cpp
bcc -c -ID:\borlandc\include -LD:\Borlandc\lib ass2.cpp
s2.obj : s2.cpp
bcc -c -ID:\borlandc\include -LD:\Borlandc\lib s2.cpp
s3.obj : s3.cpp
bcc -c -ID:\borlandc\include -LD:\Borlandc\lib s3.cpp
s4.obj : s4.cpp
bcc -c -ID:\borlandc\include -LD:\Borlandc\lib s4.cpp
s5.obj : s5.cpp
bcc -c -ID:\borlandc\include -LD:\Borlandc\lib s5.cpp
s6.obj : s6.cpp
bcc -c -ID:\borlandc\include -LD:\Borlandc\lib s6.cpp
s7.obj : s7.cpp
bcc -c -ID:\borlandc\include -LD:\Borlandc\lib s7.cpp
s8.obj : s8.cpp
bcc -c -ID:\borlandc\include -LD:\Borlandc\lib s8.cpp
s8a.obj : s8a.cpp
bcc -c -ID:\borlandc\include -LD:\Borlandc\lib s8a.cpp
s9.obj : s9.cpp
bcc -c -ID:\borlandc\include -LD:\Borlandc\lib s9.cpp
s10.obj : s10.cpp
bcc -c -ID:\borlandc\include -LD:\Borlandc\lib s10.cpp
s12.obj : s12.cpp
bcc -c -ID:\borlandc\include -LD:\Borlandc\lib s12.cpp
dragon.obj : dragon.cpp
bcc -c dragon.cpp
Reply 2 of 6, by lucky7456969
Dominus wrote:
DOSBox is for games...
Just want to write games in dosbox, is it not wise to do so?
Thanks
Jack
Reply 3 of 6, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
no, it's not wise.
First of all, why DOS games? Second, find a way to do it in your operating system and then test the games in DOSBox. As DOSBox is intended for games and not applications your compiler may run into problems it never had in real DOS.
DOSBox IS NOT SUITED TO RUN YOUR NON-GAMING DOS APPLICATION applies
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 4 of 6, by Joey_sw
more advanced linker usually support a file-list,
a simple text file that contain .obj filenames that need to be linked
dos it self, can only have up to 127 characters (including the CR character at end) in command line.
-fffuuu
Reply 5 of 6, by Harekiet
Rank DOSBox Author
DOSBox Author
Yeh openwatcom seems to do the trick here, can easily build 16/32 bit versions as well if you so wanted
Reply 6 of 6, by lucky7456969
I am able to shorten the string of linking, but
I can't have a full symbolic information even specfying tlink -v
Sorry a bit off-topic here
I get
mov [@DGROUP], ax
but not
call helloworld
but
call 0000:0000
Thanks
