Install games from DVD Drive
Reply 41 of 44, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
but no otherwise you cannot change palette but for Exodus there are some upgrade packs to make it look much better...
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 42 of 44, by Bakshara
Dominus,
I guess I should give you a tiny bit of credit.
You did say. “Seriously? Try to bring order in what you are doing and THINK. Which of all these zips do you think are for Ultima 3?
Hint: Ultima is shorted to U and then the number of the Ultima game is added.
Once you sorted that out, read the readme.txt or similar that comes with the patch on how to install it. ”
”UltimaPatcher
Ultima3Ultimapgrade
Now I have 256 EGA Colors and awesome MIDI sound!”
I use this search called Google. That is how I figured it out myself.
This was for, “How to change DOSBox size and colors” that is now locked.
Reply 43 of 44, by leileilol
Crossposting from one thread to another about a completely different issue isn't a smart way to go about things.
Debian's fucked
Reply 44 of 44, by Dominus
DOSBox Moderator
it certainly isn't.
Closing this topic as well. If Bakshara has anything personal to add, please use private messages.
Please in the future, stick to one topic, avoid crossposting (posting the same in different threads) and hijacking threads.
Good luck and take care
