Reply 40 of 53, by Skyscraper
A package from Korea arrived today!
A small box 😁
A Tualeron!
FC-PGA ready!
The CPU gets the correct voltage!
CPU-Z
I did win the MSI 6905 Master slotket but It has not arrived yet.
I get to play with this crap board while I wait 😀.
A Tualeron @ 1400 mhz with 133 mhz memory on the Biostar board scores about the same as a Coppermine Celeron @ 950 mhz with 112 mhz memory on a Abit BH6 when it comes to SuperPi.
The Biostar M6VCGs 3dmark 2001 score with the Tualeron + Quadro 980 XGL is only 6910p vs over 8000p using the Aopen AX6BC board with a Coppermine P3 1000.
This board is even bad compared to other cheap brand VIA Apollo Pro boards...
I can really see why people prefer Intel 440BX. Even a cheap BX board performs like a BX board.
It is nice to see that a FC-PGA VIA 694X board can work with a Tualeron. It should work with the P3 1400-S aswell since it supports 133 mhz FSB.
But... this is not the board you are seeking!
