Reply 20 of 319, by badmojo
- l33t
Well my second AudioDrive experience wasn’t as fun as the first. I picked up this card for a few bucks because I wanted to try out the ES1688 chipset (http://alsa.cybermirror.org/manuals/ess/PB1688B.PDF):
It works fine and actually I’d say the Sound Blaster Pro compatible side of the card sounds a little bit nicer than my first card, the 1868F. I’m no expert with this stuff but it just sounds a little bit more like a real SB Pro. This chipset was also natively supported in at least one game I tried, and that I like. This chipset also includes the ESFM synth, just like the 1868, which still sounds very nice here.
Setting it up was just as easy as before; my one and only problem with it was the wavetable header, which seems not to work. Unlike the ES688 chipset, which preceded the ES1688, this card should in theory not require a driver for the wavetable header, i.e. it’s implemented in hardware. But try as I might I just couldn’t get a peep out of it. I fiddled with jumpers, shorted a likely looking blank jumper header labelled ‘WAVE-EN’, and tried all the configuration and mixer options I could think of. No dice. The MPU401 was recognised no problem, I just never got any sound.
To confuse the issue I found this information in the deep dark recesses of the interwebs:
Wavetable Driver for DOS based Games (ES1688 only)Your sound card supports a universal wavetable daughterboard upgrade. If you have attached a wavetable daughterboard and you cannot hear background music or sound effects from the wavetable (usually General MIDI standard) synthesis chip, then quite possibly the game you are using does not include a driver for wavetable synthesis (an example = "Doom2"). In this case you need to enable the Wavetable Driver included on diskette # 1/1. Install as follows..• Install DOS drivers as stated above.• The process of DOS driver installation will create a directory called PCAUDIO. Go to this directory on your specific drive (usually C:\PCAUDIO\) by typing CD PCAUDIO at the C:\ prompt.• Type EN1688 - This will install the wavetable driver.
I did manage to track down ‘EN1688.exe’ but all it seem to do was dynamically move the card from IRQ 5, to IRQ 7. Still no action from the wavetable.
I know this chipset was sometimes coupled with ESS’s version on onboard wavetable syntheses, which is what I presume the blank IC placeholders are for on the card I have, but if you’re gonna include an external wavetable header too, then why not make it functional?
Anyway I have another card with this chipset on the way so hopefully I have more luck with that one. If the wavetable header worked, I think this card would have topped the ES1868F.
