First post, by blakespot
I am finally ready, in this 486 build, to try and get the i486 66 replaced by the AMD 5x86 running @ 160.
When I boot, the system reports:
Award Modular BIOS v4.50PG
#401A0-0305
Am I good? To run 5x86 at 160 you set to 2x clock right? Isn't that the trick? Thanks.
bp
:: Visit the Byte Cellar, my vintage computer blog (since 2004).
:: See a panorama of my own Byte Cellar (a.k.a. basement computer room)...
:: twitter: @blakespot
Reply 1 of 2, by Robin4
I think you better try it out. Depends on the bios version you have. Iam not sure, but iam guessing the the ABIT AH4-T motherboard uses the same bios..
I still waiting on an ABIT AH4-T motherboard which arrives in couple of days here. Then actually can see if its the same bios version.
Most ISA/VLB do not support it.. On PCI boards the chance it defently higher.. Most ISA/VLB board will do till DX4 120 Mhz it seems.. Only high-end boards will support AMD 5X86 cpu.
Reply 2 of 2, by 5u3
blakespot wrote:
#401A0-0305
#401A0-0306 does support the AMD 5x86, so chances are pretty good.
And yes, the 2x multiplier is remapped to 4x on this CPU.
