First post, by bjwil1991
Hello, fellow DOSBox Team.
Here's a quick summary of how things are going in the build I am making using Microsoft Visual C++ 2008 Express Edition:
1. Got all of the files copied onto my hard drive
2. Made a patch file called gate.diff for the Frederik Pohl's Gateway MT-32 Missing Music Patch (fix)
3. Tried making the program, dosbox.exe, and ended up getting errors when I included the gate.diff file in the dosbox.cpp file with this line of code:
#include "gate.diff"
4. Commented out the code, and got a fatal error trying to link the sdlmain.lib file
5. Copied the file to C:\development\dosbox-0.47\visualc_net and got 3 warnings and no errors; successful build
Now my main question is: how do I apply the patch file to the program? This is my first time developing software; I followed the step-by-step basis on:
http://www.dosbox.com/wiki/Building_DOSBox_wi … _C_2008_Express
Main reason I'm making the program is because I have to check to see if using the patch file would make my Frederik Pohl's Gateway Game work with the Roland MT-32 (munt) and post details about it.
Thanks.
-bjwil1991
Reply 1 of 6, by Qbix
Rank DOSBox Author
DOSBox Author
patch -p0 < gate.diff
or use something TortoiseUDiff (part of tortoiseSVN)
Water flows down the stream
Reply 2 of 6, by bjwil1991
Qbix wrote:
or use something TortoiseUDiff (part of tortoiseSVN) […]
when using the command, I get this error:
C:\Users\Ben\Desktop\GetGnuWin32\bin>patch -p0 < gate.diff
patching file src/hardware/mpu401.cpp
patch unexpectedly ends in middle of line
patch: **** malformed patch at line 10:
gate.diff file:
1 --- src/hardware/mpu401_orig.cpp   2014-01-07 14:27:05 -0500
2 +++ src/hardware/mpu401.cpp 2014-01-07 14:30:58 -0500
3 @@ -210,8 +210,8 @@ static void MPU401_WriteCommand(Bitu por QueueByte(0));
4 return;
5 case 0xac: /* Request version */
6 -QueueByte(MSG_MPU_ACK);
7 QueueByte(MPU401_VERSION);
8 +QueueByte(MSG_MPU_ACK);
9 return;
10 case 0xad: /* Request revision */
11 QueueByte(MSG_MPU_ACK);
I've attached the file on here, in case the line/lines of code is/are incorrect.
Reply 3 of 6, by bjwil1991
Fixed the issue. Go to viewtopic.php?f=32&t=37884&start=60#p339120 and click on the link to download the file DOSBox-SVN-GATE.zip
These are the following files that are in the DOSBox-SVN-GATE.zip file:
munt-1.3.0-win32.exe
SDL.DLL
SDL_NET.DLL
DOSBox.exe
Munt readme.txt <-- read that file first prior to running the program.
Edit: removed the ROM files as requested by Dominus. Get your own, or use a Real Roland MT-32 (recommended).
Reply 5 of 6, by bjwil1991
Dominus wrote:
Please remove that. The mt32 ROMs are of dubios nature and you can't link to those here.
As requested, I have removed the ROM files and recreated a new zip file without the ROM files. You don't mind that I left the munt installation file in the zip file, right?
