First post, by vogge
Hi!
Some questions from a newbie in retrodosgaming on real hardware.
I just installed an old compaq with Freedos. It has an ESSSOLO-1 soundcard, and I tried space quest 5 on it. The soundcard is found by the initial dossetup,and seems to be found correct. When configuring SQ5 there's two choices.
Music: Soundblastercomp ... and so on
Audio: Sound blaster ... and so on
I can choose Music: and get music in-game, but when also choosing Audio; Sound blaster, it says hardware not found. Altough both the Music: and Audio: Menus are shown as "found in your system" though.
So, is the ESSOLO-1 card supposed to support the audio also, or can it only support the music part? IE ist there something wrong with my setup?
I guess i'll miss all the soundeffects if it can't find Audio:, only Music:?
Also, do i need the BLASTER variable when using ESSOLO-1 for SB-emulation to work?
