The Little Tandy That Could
Reply 20 of 23, by Cloudschatze
So, the SupraSonic, despite being the coolest modem ever made, has the ridiculous quirk of not supporting DTE rates of 300-baud. This, as everyone knows, means that head-to-head Battle Chess is out of the question.
Obviously, a sidekick is needed... some sort of corresponding Robin to the SupraSonic's Batman, as it were...
Shazaam!
Reply 21 of 23, by snorg
How on earth did you hook a CD-RW to it and wifi? I see the Xircom parallel port adapter, is the wifi somehow hooked up to that? The CD-RW has to be SCSI then, right?
Reply 22 of 23, by Cloudschatze
A 3-foot ethernet cable connects the Xircom adapter to the ASUS WL-330N, which acts as a wireless bridge to the household wireless router. Using Mike Brutman's mTCP package, FTP transfers (and hosting), HTTP downloads, Telnet, and IRC connectivity are possible. The Arachne web browser also works on this system, albeit so slowly as to render it pretty-much unusable.
Correct. The single ISA slot in this system is populated with a Trantor T-130B SCSI adapter, with the CD-RW and PCD-47B both sitting on the SCSI bus.
Reply 23 of 23, by butterfly
Neat, definatly!
